Sponsors
Wired Designs
Aanraku Glass Studios
American Glass Supply
Anything in Stained Glass
Artisan Dichroic
Blue Fire Molds
Bullseye Glass
CBS Dichroic
COE90.com
Centre DeVerre
D&L Art Glass Supply, Inc.
Delphi Glass
Dichro Depot
Dichroic and More
Ditore Glass Works
Ed Hoy's International
Evenheat Kilns
Hang Your Glass
Hippos Eating Alligators
His Glassworks
Hot Glass Houston
Lincoln Distributors
Nabertherm USA
Nartique Glass
Olympic Kilns
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
TMS Studios
The Curious Glass Shop
The Joy of Coldworking
UGotGlass?
Uroboros Glass
Warm Glass UK
Warm Tips
Wasser Glass
Glass Types and Forms
In addition to compatibility, glass artists also differentiate among different types of glass in many different ways. One of the major criteria for differentiation is the transparency of the glass. Opaque glasses that do not transmit light are generally referred to as "opaques", as "opalescent" glasses, or as "opals." See-through glasses of various colors are usually called "transparent" or "cathedral" glasses. Combining more than one different opalescent or cathedral glass or color in a single kiln-formed work is common.
Several different companies offer lines of tested compatible glass, with the largest and most popular being Bullseye and Spectrum.  Other companies offering tested compatible glass include Uroboros, Effetre (Moretti), Wasser, and Gaffer.
Bullseye, which has produced tested compatible glass since the 1970's, is generally acknowledged as the market leader, with a broader product offering than Spectrum or other brands.  Spectrum's tested compatible program, initially launched in Spring 2000, contained glasses made by both Spectrum and Uroboros, and is marketed under the "System 96" name.  Although the two product lines behave similarly in the kiln, they are not compatible, so most glass artists and hobbyists choose one or the other brand as their primary glass for fusing and slumping.
It should be noted that Bullseye, Spectrum, Uroboros, and many other firms also manufacture glass that is not guaranteed compatible. (A complete list would also include companies such as Armstrong, Desag, Freemont, GNA, Kokomo, Wissmach, and Youghiogheny.  Sometimes the glasses made by these companies tests compatible for fusing, but often it does not.  If you wish to use any of these glasses for kiln-forming projects involving more than a single sheet of glass, you will need to test for compatibility.
Virtually any stained glass, whether tested compatible or not, can be treated with an iridescent coating that causes the treated side of the glass to take on a metallic sheen. Some liken this effect to a shimmering rainbow. The shimmer goes away when the piece is lit from behind, allowing the normal color of the glass to shine through.
Another popular kind of glass coating, called "dichroic",  has the unusual property of reflecting one color while it transmits another. This means that the different colors can be viewed by examining the glass at different angles.   This unique glass is manufactured by spraying a thin chemical film on the glass. This must be done in a controlled environment in a vacuum chamber, making dichroic glass one of the most expensive glasses made for kiln-forming. Because of this expense, dichroic glass is more commonly used in jewelry and similar items, or as an accent in larger scale fusing projects.
One final type of glass that is often used for kiln-forming is "float" glass.  Made by "floating" molten glass on a bath of molten tin, float glass is better known as common window glass. It is inexpensive and widely available. It also works well in the kiln, but care should be taken to test for compatibility if different brands and types of float glass are mixed together. If at all possible, cut pieces to be fused together from the same glass sheet.
Although some colored varieties of float glass are available, it is most commonly found in a clear (often slightly greenish) formulation.  It tends to slump and fuse at slightly higher temperatures than most art glass (about 75 to 100 degrees F higher), and can be prone to devitrification. Its COE depends on the specific formulation used and can be as low as 83 or as high as 90, but it generally ranges from 85 to 87.
SHAPES AND SIZES
Glass is available in several different shapes and sizes, the most common of which are:
Sheet glass - relatively flat, up to 30" wide.  Sheet glass is typically 1/8" (3mm) thick, but thinner and thicker varieties are available.
Frit - small, irregularly shaped glass pieces, available in sizes that range from around 1/2" (6mm) in width to powders.
Stringer - long, thin threads of glass, about 1mm in diameter and up to around 18 inches (45cm) in length.  Some thicker stringer and related shapes (called "noodles") are also available from some manufacturers.
Rods - round cylinders of glass, about 4-5mm in diameter and up to around 18 inches in length
Shards and confetti - slices of glass that are slightly thicker than a sheet of paper
Cullet, billets, patties, and dalle - various sizes and shapes of glass "chunks" used primarily for casting
This tutorial is a condensed version of copyrighted material from Brad Walker's book, Contemporary Warm Glass: A Guide to Fusing, Slumping, and Related Kiln-forming Techniques
Please click here to learn more about the book.
Click here to go to the next item in the Tutorial section,
"The Basic Fusing and Slumping Process."
