Sponsors
Olympic Kilns
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
TMS Studios
The Joy of Coldworking
Uroboros Glass
Warm Glass UK
Wasser Glass
A&A Products
Aanraku Glass Studios
American Glass Supply
Anything in Stained Glass
Armstrong Glass Company
Artisan Dichroic
Blue Fire Molds
Bullseye Glass
COE90.com
Contemporary Fused Glass.
Curious Glass Shop
Delphi Glass
Dichro Depot
Dichroic and More
Ed Hoy's International
Evenheat Kilns
Hang Your Glass
His Glassworks
Hollander Fusing Center
Hot Glass Houston
Kiln Frog
Lincoln Distributors
Nartique Glass
Sample Coaster Designs
You may copy or modify any of these design in whichever way you'd like.
For full fusing projects make sure you use at least two full layers of glass.
This simple sketched design can be made by cutting the two thin dark stripes and laying them on top of a solid design layer. When the coaster fuses, the stripes in the layer on top will simply melt into the layer below.
Using a dark border around a glass square works best when an iridescent or strongly patterned glass is used as the central piece.
For this design, the design layer is composed of three pieces that fit together to form the square. Stringers (or very thin pieces of glass) are used to add an abstract pattern on the top of the coaster.
For this design, select four different colors and arrange them so that no two colors touch each other. By staggering the arrangement, you can make a set of four matched coasters with no two being exactly alike.
Curved lines, like those used in the coaster at the left, often make for a more interesting coaster design than straight lines alone.
