Sponsors
Contemporary Fused Glass.
Curious Glass Shop
Delphi Glass
Dichro Depot
Dichroic and More
Ed Hoy's International
Evenheat Kilns
Hang Your Glass
His Glassworks
Hollander Fusing Center
Hot Glass Houston
Kiln Frog
Lincoln Distributors
Nartique Glass
Olympic Kilns
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
TMS Studios
The Joy of Coldworking
Uroboros Glass
Warm Glass UK
Wasser Glass
A&A Products
Aanraku Glass Studios
American Glass Supply
Anything in Stained Glass
Armstrong Glass Company
Artisan Dichroic
Blue Fire Molds
Bullseye Glass
COE90.com
GLASS ENAMELS
Although traditional painting on stained glass is probably the most common way of painting on glass, painting with glass enamels has grown significantly in popularity the last few years. The range of colors is extensive, and the ability to mix colors means that a virtually unlimited palette is available.
These "paints," which like traditional stained glass paints are actually finely ground glass particles with a relatively low melting point, are available in both transparent and opaque colors. They are applied, then fired onto the glass using a kiln.
Because glass enamels are made of tiny glass particles, care must be taken to ensure that they are compatible with the base glass being painted on. As with any other glass, using incompatible enamel will result in cracking or poor adhesion.
Care must also be taken when using glass enamels that the fine particles are not inhaled. A respirator or mask is recommended to prevent this, as inhaling fine glass particles can cause silicosis, a serious and potentially fatal lung condition.
There are a number of ways in which glass enamels may be applied, but in most cases the enamels are applied and fired in several layers. This maintains the integrity of the colors and also helps to achieve effects that would not be possible in a single firing. It is not uncommon for enamels to require four or five or more firings before the work is complete.
The most common ways to apply glass enamels are by brush, by dry sifting the enamels onto the glass, and by screen-printing.
Back to top
BRUSH APPLICATION
To apply enamels with a brush, you must first mix the glass particles with a liquid (called a "medium") to obtain a paint-like consistency. Mediums may be oil or water-based, but water-based mediums have the advantage of generally being safer and easier to clean up. The key criterion is that the medium fires clear without leaving a residue. Commercial preparations are available, but good results have been reported from using substances as common as 7-UP (or Sprite, if you prefer).
The proper consistency for painting is approximately one part enamel to two parts medium, but this can vary depending on the particular enamels used. It's a good idea to mix the paints on a smooth surface (a sheet of window glass is ideal), adding the water drop by drop until the desired consistency is reached. Sometimes the paint will dry out a bit during painting and you will need to add a few extra drops of water.
Any brush may be used, but recognize that transparent enamels tend to show brush marks. Take advantage of this by using the brush to create desirable patterns and textures. (Opaque enamels are less likely to exhibit this trait.)
Once application is complete, the enamels should be allowed to dry prior to being kiln-fired. Enamels will mature at various temperatures, with opaques generally requiring higher temperatures (around 1450 degrees Fahrenheit) and transparents needing only to be fired to around 1200 degrees F. For enamels that fire at this lower temperature, it is possible to both slump and fire on enamels in the same firing. Many of these lower-firing enamels contain lead, so care should be taken not to use them on food-bearing surfaces.
It's possible to achieve significantly different results by varying the method of brush application. The enamels can be mixed very thin and splattered onto the glass a la Jackson Pollock. They can be applied, allowed to dry, then scratched partially off to yield interesting patterns. Often, the best results come from very thin applications and multiple firings; thicker applications tend to result in a dark, muddy appearance.
Also, many glass artists use "reverse painting" techniques. This approach, which is contrary to "normal" painting techniques which start with the background and add details as a final step, starts on the backside of the sheet of glass. Working from the top layers to the bottom, successive layers of paint are added and fired until the picture is complete. Although the approach appears strange at first, it results in a work with an exceptionally clear and glossy surface.
Remember that when firing enamels you must follow the normal warm glass procedures to heat, anneal, and cool the glass to prevent cracking and thermal shock. Fired properly, the enamels will bond to the glass, resulting in a permanent, lustrous finish.
Back to top
DRY APPLICATION
Glass enamels can also be applied dry. To do this, simply place a small amount of enamel powder in a sifter and sift. You can add interest by drawing patterns in the sifted powder or masking off a portion of the glass "canvas" to control where the powder goes.
If you work with glass enamels, it's a good idea to wear a mask to keep from inhaling the glass particles. This is especially good advice if you are sifting and working with dry enamels, which can easily become airborne.
Click here to go the next use of glass enamels to paint on glass, Screen Printing.
