Sponsors
Dichro Depot
Dichroic and More
Ditore Glass Works
Ed Hoy's International
Evenheat Kilns
Hang Your Glass
Hippos Eating Alligators
His Glassworks
Hot Glass Houston
Lincoln Distributors
Nabertherm USA
Nartique Glass
Olympic Kilns
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
TMS Studios
The Curious Glass Shop
The Joy of Coldworking
UGotGlass?
Uroboros Glass
Warm Glass UK
Warm Tips
Wasser Glass
Wired Designs
Aanraku Glass Studios
American Glass Supply
Anything in Stained Glass
Artisan Dichroic
Blue Fire Molds
Bullseye Glass
CBS Dichroic
COE90.com
Centre DeVerre
D&L Art Glass Supply, Inc.
Delphi Glass
NON-FIRED
PAINTS MADE FOR SURFACES OTHER THAN GLASS
It's possible to paint on glass with paints that are made for painting on other surfaces. All you need some paint and a desire to experiment. Oil paints and acrylic paints can work, as will widely available alternatives such as model paint or automobile paint.
These kinds of paints can be brushed on by hand, but airbrushing frequently yields better results.  The advantages of this approach to painting on glass are that the paints are easily found, relatively inexpensive, and can be mixed into virtually any color. In addition, no kiln is required, although firing in a kiln can help oil paints dry and adhere better.
The disadvantage is that since a kiln is not used to permanently fuse the paint to the glass, paints made for other surfaces have a tendency to peel or chip when used on glass.
To counteract this tendency and increase the life span of the paint, you should concentrate on thoroughly preparing the surface of the surface of the glass. Sandblast if at all possible. At a minimum, rough the surface up with wet/dry sandpaper. Roughing the surface in this manner will help the paint adhere better and last longer. Applying the paint with an airbrush, rather than by hand, also tends to yield better results.
Back to top
AIR-DRIED AND OVEN-CURED GLASS PAINTS
here are a number of "glass painting" books on the market which promote this kind of painting as a substitute for stained glass. In this approach, the painter starts with a clear sheet of glass, then colors the glass in a pattern that approximates "real" stained glass. Sometimes practitioners of this style even go so far as to apply paste outlines designed to resemble stained glass lead or solder lines.  In general, people who make stained glass frown upon this style of glass painting.
These paints do, however, have the advantage of being specially formulated for painting on glass. They come in two varieties: air-dried and oven cured.
As the names suggest, air-dried glass paints are simply applied and then allowed to dry (drying takes about eight hours). These paints are most suitable for decorative purposes on surfaces that will not be handled much. In most cases they can withstand only light washing in cold water, and are not suitable for food-bearing surfaces or items that will be handled.
Oven cured paints are a bit more durable. They require the use of a conventional kitchen oven to heat the glass to around 300 to 400 degrees F. This is hot enough to help bond the paint to the glass and will adhere better than glass that isn't heat-set at all, but the temperature isn't hot enough to fuse permanently.
Delta and Pebeo are among the best known manufacturers of air-dried and oven cured paints.
Click here to go to the next section, which is on painting with glass enamels.
