Sponsor list
Pacific Art Glass
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
Two Lasses Glass Classes
UGotGlass?
Uroboros Glass
Warm Glass UK
Warm Tips
Wasser Glass
Wired Designs
A & A Products
Aanraku Glass Studios
Art Glass Fusing Center
Artisan Dichroic
Best Mix Mold Mix
Bullseye Glass
CBS Dichroic
COE90.com
Centre DeVerre
Evenheat Kilns
Future Forms Molds and Stands
GlassStands.com
Hang Your Glass
His Glassworks
Lincoln Distributors
Nabertherm USA
Olympic Kilns
Orton Ceramic
OTHER PHOTOGRAPHIC AND PRINTING TECHNIQUES
It is also possible to print on glass using other photographic, printing, or xerographic techniques. Aside from technical competence, the key to success is using glass enamels or similar glass paints so that the image becomes permanent.
Of these techniques, the simplest is probably the use of the screen-printing process to achieve photographic detail. Both require either a black and white rendering or a film positive (a photo developed using a positive halftone film which converts the photo into dots). Transferring of the positive to the screen is accomplished by one of two main methods.
Direct screen emulsion. In this process, the film positive is applied directly to the mesh screen. To do this, a photosensitive emulsion is applied to the screen, then a film positive is place beneath the coated screen. By exposing the emulsion to a bright light, the pattern on the film positive is transferred to the screen.
Indirect emulsion. In this method, the image is first exposed to a film, then the film is developed and applied to the screen. This approach is easier than the direct method, but it requires the use of an oil-based medium, rather than the water-based medium most frequently used with glass enamels.
There are a number of companies which make direct and indirect screen emulsion supplies. Among these are Ulano and Speedball.
In addition to screen-printing techniques, many conventional photographic techniques can also be adapted to print on glass. The key adaptation centers on the use of glass enamels as the pigment. In addition, there are many non-kiln-fired processes (such as photo embossing, xerography, and engraving) which produce an image and which can be adapted to glass.
The use of print-making techniques to print on glass was pioneered by Harvey Littleton, the father of the studio glass movement. Glass can make an excellent printing plate or surface to be printed on. Glass enamels can be used as a pigment and fired onto the glass or (although they are not as permanent) the printing can be accomplished with conventional sign painter's enamels and epoxy paints.
Return to top
Click here to e-mail comments
4140 Clemmons Road, #320
Clemmons, NC  27012   USA
