Sponsor list
Artisan Dichroic
Best Mix Mold Mix
Bullseye Glass
CBS Dichroic
COE90.com
Centre DeVerre
Evenheat Kilns
Future Forms Molds and Stands
GlassStands.com
Hang Your Glass
His Glassworks
Lincoln Distributors
Nabertherm USA
Olympic Kilns
Orton Ceramic
Pacific Art Glass
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
Two Lasses Glass Classes
UGotGlass?
Uroboros Glass
Warm Glass UK
Warm Tips
Wasser Glass
Wired Designs
A & A Products
Aanraku Glass Studios
Art Glass Fusing Center
PATE DE VERRE
Pate de verre involves making a paste of glass that is applied to the surface of the mold, then fired. The big advantage to pate de verre is that it allows for precise placement of particular glass colors in the mold. Other ways of filling the mold often result in some shifting of glass from where it has been placed prior to firing, but the pate de verre process helps to control this shifting.
Pate de verre dates back to the ancient Egyptians, but it really came into its own about a century ago when it was revived by a group of French artists who gave this warm glass technique its current name.
In traditional French pate de verre, the artist mixed crushed glass with enamels or paint to form a paste that was carefully placed in a mold and then fired. Many of the pieces that were made using this technique were relatively small, elaborately decorated, and required more than one firing before they were complete.
The modern equivalent builds on this traditional foundation. Generally the pate de verre process involves creating a paste from frit (small particles of glass). Frit of any size may be used, but most good glass pastes require smaller sizes (even powders) to be used. For this reason (and because the smaller the pieces of frit the more opaque the casting), pate de verre castings tend to be translucent (or even opaque).
Once the mold is thoroughly dry and the frit has been secured, the next step is to make the glass paste. In some cases, where the mold has gently sloping sides, the glass can simply be mixed with distilled water to form the paste. Most molds, however, will require that glue be mixed with the glass to form the paste. Special glues can be purchased, but white glue or gelatin diluted with distilled water will generally work well. It’s a good idea to wear a mask or respirator while mixing the paste to prevent inhaling small glass particles.
Use a brush or thin palette knife to apply the glass paste to the sides of the mold. Start with a relatively thin coating (about 1/16"). Some artists fire this initial coating to tack fuse (about 1400 F), others let it air dry or use a hair dryer to speed up the process. After the first layer dries, a second layer of paste should be added to bring the total thickness to around 1/8" (3 mm). Gently pack the layer down as much as possible.
If your mold is hollow or slopes significantly, you will need to pack the inner surface of the mold to prevent glass movement during firing. Sometimes a second mold is created to fit inside the first mold. Alternatively, you may pack the mold with fiber paper to prevent the glass from slipping out of place.
Click here to go to the next part of the Kiln Casting section, "Firing the Casting."
Return to top
Click here to e-mail comments
4140 Clemmons Road, #320
Clemmons, NC  27012   USA
