| Now shipping! Contemporary Fused Glass The new edition of Brad's book |
Lauri Levanto wrote:lauri: Artista has machine rolled reds and yellows that they say are not compatible,
and are replaced by Uroboros colors which look like hand rolled.
Well, you can throw almost anything together and sometimes it survives. ...
Lauri Levanto wrote:Lani,
I need something hammered through my skull.
When you stated that BE on top of Artista thins out,
do you mean
- in full fuse or
- even tack fuse - where BE contracts more but later and
is streched a bit thinner?
-lauri
I promise to study some European sites what they say about compatibility.
Bill Ward wrote:Wow, there sure is a lot of mis-information in this thread. I thank the person that said you should check with the manufacturers to get product information.
First, Uroboros Glass is very committed to our 90 COE palette. We make hand rolled 'double rolled' clear (60-00-90) along with 92 other hand rolled sheet products in this range. In the last year we have added 12 new products to this group. We also have a full compliment of machine rolled clear products that are widely accepted in the industry, now available in 3 thicknesses and iridescent. We have more than 700 additional 90 COE accessory products to go with the 90 COE sheets.
Regarding the testing of fusing glass we are aware of three other manufacturers that use a fused interface testing method besides Uroboros. These are Spectrum, Schott (Artista) and Bullseye. This test method takes into account several relevant properties such as COE, viscosity, and surface tension and their affect on compatibility. These properties are completely interdependent on each other and cannot be isolated when measuring compatibility. These stress measurment tests must be carried out against a known historic standard. Quantitative measurements of stress are usually made by using a calibrated polarimeters, as are used at least by Uroboros, Spectrum and Schott.
Regarding the Schott Artista product group it should be noted that it was stated that their machine drawn red and yellow are not compatible with the Artista line. I understand this to be true, and it is the reason they stock hand rolled, fuse tested, red, yellow and orange sheets. Schott is a multi-billion dollar century old glass firm that produces the thinnest glass in the world as well as scientific and many other technical glasses. You can be pretty sure they have both the resources, knowledge, and will to provide thorough testing for their fusing products. I recommend that you contact Schott if you have questions regarding their products and get the answer from the source.
Uroboros does not recommend combining Uroboros 90 or System96 with Artista. On the other hand, our 90 was designed to be compatible with Bullseye Tested Compatible and these have been comingled successful by many artists since 1989.
Hope this helps to clear up some misunderstandings.
Bill Ward
Uroboros Glass
Lauri Levanto wrote:P.s. I still wonder what difference it makes if a piece
of BE is under or over Artista?
Lauri Levanto wrote:Quote:
Regarding the Schott Artista product group it should be noted that it was stated that their machine drawn red and yellow are not compatible with the Artista line. I understand this to be true, and it is the reason they stock hand rolled, fuse tested, red, yellow and orange sheets. endofquote
Lani:
Bill, it is common knowledge that the reds and yellows in the Artista line are made by Uroboros. This fact is reinforced by US distributors who present them within the Artista offering in their catalogs:
http://www.crloo.com/Products/Sheet_Gla ... ed_90.html
The last three items on this Artista chart are clearly Uroboros products:
AR-120-90 - Red 90 coe SEE U-60606-90
AR-105-90 - Lemmon Yel 90 coe U-60357-
AR-115-90 - Orange 90 coe SEE U-60608-
That is really obscure. I have not seen those glasses
on Schott material, until yesterday I noticed that
they were included in their sample pack.
I told earlier to my retailer that they are Uroboros,
He contacted the imported, who could not verify
or deny that.
No wonder dealers and end users are confused.
-lauri
Kevin Midgley wrote:Brian your post tells the story experienced glass workers know. That it is always wise to extra anneal from posted schedules. The extra anneal is to take into account any unknown variable that may exist in the materials you are using.
Of course as soon as you start combining different source glasses despite their being officially combinable, there have to be unknown variables contained within them. The extra annealing is required to ensure success.
Perhaps the manufacturers could get together and create shedules that take this into account?
Return to Techniques and Tools
Users browsing this forum: Google [Bot], Jim Murphy, john Kempson and 3 guests
