Felisatti question - WarmGlass.com
Felisatti question
Lisa Allen
Felisatti question
Postby Lisa Allen » Fri Mar 14, 2003 2:26 pm
Is this tool meant to replace a standing wet belt sander or is it for a more specific purpose? I have had a belt sander on my wish list for a while,but ultimately don't really have the room for it. But I would have the room for this hand held.....especially if it would serve the same purpose.
Lisa Allen
http://www.lisa-allen.com
Steph Mader
Angle grinders
Postby Steph Mader » Fri Mar 14, 2003 3:24 pm
Hi Lisa,
When Doug Randall showed it in his coldworking workshop, he used it to grind & polish a large flat surface. That's difficult to manage on a wet belt sander, which is better for smaller surfaces like edges.
I do some cast panels, I'll be using mine on the backs of those panels. By the way, I called Granite City tools and they don't have the Italian one anymore, but do have a couple other water-feed grinders.
Steph
Amy Schleif-Mohr
Postby Amy Schleif-Mohr » Fri Mar 14, 2003 4:12 pm
Huh? When did you call?
I called a week and a half ago and ordered it and it arrived a few days later.
Amy
Lisa Allen
Re: Angle grinders
Postby Lisa Allen » Fri Mar 14, 2003 4:50 pm
Thanks, Steph. I am guessing if you had a way t stabilize the piece, you could probably work the edges as well? Might be a better alternative to a big, cumbersome belt sander if space is an issue.
Thanks again, Lisa
Steph Mader wrote:Hi Lisa,
Steph
Lisa Allen
Steph Mader
Amy, did you snag the last one???
Postby Steph Mader » Fri Mar 14, 2003 6:11 pm
I called I think wednesday.
Steph :shock:
Cynthia
Postby Cynthia » Fri Mar 14, 2003 6:16 pm
Amy Schleif-Mohr wrote:Huh? When did you call?
Amy
The info I got from them was that they weren't going to carry the electric one anymore, just the one that attaches to a compressor. So I am holding off until I get a sandblasting system. Not gonna get a compressor until then, so will wait.
:?: Is your's the electric one Amy?
Amy Schleif-Mohr
Postby Amy Schleif-Mohr » Fri Mar 14, 2003 6:37 pm
Yep, I guess I got one of the last ones. Hmm.
Amy
Beth
Postby Beth » Fri Mar 14, 2003 7:40 pm
I talked to Granite City Friday evening and they have them. The person I talked to said he was literally looking at a stack of about 20 as we were speaking. He said they had been back-ordered for a while, but had plenty now.
If you call again and are told they are out, feel free to ask for Kent Brown. Very nice man, baffled about why anyone was told there weren't carrying them. ("Them" is the Felasatti WG20 Variable Speed Angle Grinder.)
:?: for Amy or Doug
The only question was which pads. Kent said there were several types of resin diamond edge polishing discs, and that besides size, a part number or brand is needed.
Beth
Amy Schleif-Mohr
Postby Amy Schleif-Mohr » Fri Mar 14, 2003 8:16 pm
I have the 4" ones. I don't have a part number.
Sorry I can't help more.
A
Doug
Angle grinder pads
Postby Doug » Fri Mar 14, 2003 10:23 pm
I purchased the complete set of diamond pads, I think 40 grit up to 3500 though I could be wrong about the grit sizes. I'll be at the shop tomorrow am and get the brand and grit sizes. I was amazed that by buying the complete set of 8 it was really inexpensive, like about 180- along with the backer pad. (For those that don't know, the backer pad is a rubber pad with a threaded fitting that threads right onto the grinder. On the surface of the rubber pad is some velcro like material in which you can stick the diamond grinding pads on to since they like wise have velcro on them.) wfd
Beth
Postby Beth » Fri Mar 14, 2003 10:41 pm
Thanks Doug! Granite City is holding my grinder until I let them know which pads I want.
I was surprised to hear you don't have to use any abrasive medium with the angle grinder - just water.
We watched Steve Klein completely hand finish a piece of glass just using diamond pads and water, but he ended with a 600 grit pad and 500 grit aluminum oxide, or so Nikki remembers. Of course it took a long time and students worked on it too. The finish was so soft it was amazing.
I guess you don't need a finishing medium because you are using so much finer a pad and at faster speeds?
Also wondered if the grinder was heavy to hold for long periods, or any hints about use or typical amount of time at various levels. I assume you rough up the glass with the 50 pad (instead of blasting) and then bring it back to smoothness.
Thanks very much,
Beth
lohman
Postby lohman » Fri Mar 14, 2003 11:23 pm
This grinder discussion is just in time. I've been considering buying one . So how large was this surface Doug Randall did in his workshop and how many man-hours did it take? I'm assuming this will put a high polish on the edge of a 20" diameter bowl or plate?
Postby Tony Smith » Fri Mar 14, 2003 11:52 pm
Because it is a hand held grinder that sprays water all over the place, it is better suited to put a high polish on the face of a 20" diameter than on the edge. And that might take a couple of hours after a lot of practice.
Doug
Postby Doug » Sat Mar 15, 2003 4:11 am
We just used a small fused blank about 8" square and because of the time constraints of the class (1/2 day) everyone only had a few minutes to practice with it. It can do edges as well as surface with a little practice and could take a 20" surface to a sheen in an hour or three.
Candy Kahn
Postby Candy Kahn » Sat Mar 15, 2003 1:03 pm
Hi,
What a timely discussion for me too. What is the cost of this grinder and does someone have a web address for the vendor?
candy
Candy Kahn
Art in Glass
Jane Lindell
Postby Jane Lindell » Sat Mar 15, 2003 1:14 pm
Candy:
This topic started in a thread further down "Wet grinder question for Doug"
The link to the supplier is:
http://www.granitecitytoolvt.com/specialsales.html
The Felisatti is at the bottom of the page.
Good luck
Jane
Doug
Postby Doug » Sat Mar 15, 2003 1:16 pm
When I first bought it less than 2 years ago it was $284- and I've seen it as recently as a few months ago at the same price. With the pad sets and backer pad plus shipping you could have a nice grinding and polishing setup for about $450-500.
Cynthia
Postby Cynthia » Sat Mar 15, 2003 1:20 pm
Doug wrote:We just used a small fused blank about 8" square and because of the time constraints of the class (1/2 day) everyone only had a few minutes to practice with it. It can do edges as well as surface with a little practice and could take a 20" surface to a sheen in an hour or three.
:?: What are the grits of the disks/pads and that should be purchased with this tool? Any other accessories or add ons that would be necessary or useful?
Brian and Jenny Blanthorn
Postby Brian and Jenny Blanthorn » Sun Mar 16, 2003 6:40 am
Candy Kahn wrote:Hi,
candy
His sell this sort of stuff and more
A very good site just 2 look n FAQ ( support ) is full of good stuff
http://www.hisglassworks.com/index.html
Amy Schleif-Mohr
Postby Amy Schleif-Mohr » Sun Mar 16, 2003 11:13 am
I paid around $400 for the grinder, backer pad, and 4 or 5 discs.
The phone number is 1800-328-7094
Amy
Users browsing this forum: No registered users and 61 guests
