All of a sudden my sandblaster is blasting large (relative) chips out of the glass I am blasting. I'm not sure what has changed since I am now on about the 40th piece all done the same. I have replaced the nozzle, added grit, checked for water in tank and generally used a lot of foul language. Could it be....
1 - Grit getting contaminated (silicon carbide 80#)?
2 - Bad batch of glass (black irid)?
3 - Something like....
Or a dumb operator who doesn't see the obvious which is.....
All suggestions welcomed and appreciated!
What has gone wrong (sandblasting) here?
Ron Bell
Black Creek Glass
Black Creek Glass
This is a new one on me. You haven't been crushing your own grit out of rocks? Have you?
Try emptying your grit and sifting it through a screen... a regular window screen should be sufficient. I can't imagine that your abrasive is sticking to itself and forming small rocks, but that's what it sounds like. The fact that it's getting through the nozzle is also surprising. The screen should sort it out.
Also, make sure you drain your water trap as, this time of year, moisture can be a real problem.
You may be firing small bits of glass at your glass, but the screen should take care of that as well. It's a good idea to screen your abrasive every time you fill your pressure pot, or periodically if you use a siphon blaster. It eliminates a lot of problems later.
Darrin Strosnider
Re: What has gone wrong (sandblasting) here?
Ron- you didn't say anything about the air pressure. Is your pressure at the compressor still the same, as well as the setting on the ratio mixing valve (if you have a pressure pot)?Ron Bell wrote:All of a sudden my sandblaster is blasting large (relative) chips out of the glass I am blasting. I'm not sure what has changed since I am now on about the 40th piece all done the same. I have replaced the nozzle, added grit, checked for water in tank and generally used a lot of foul language. Could it be....
Tony's suggestion for straining again is on the money. Once you blast a "chunk" of glass out- it has to go somewhere. It's possible that you are firing those chunks at your ware now, and creating even more chunks to fire...
-stro
