Problem Slicing Pattern Bar
Melissa Terman
Post by Melissa Terman »
As I'm slicing through a pattern bar, when I get to the very end of the slice it cleaves and ruins the cut (and my need for perfection). I'm slicing on a MK 101. The water feed is working and everything appears fine, until I get to the very end and snap.
Your input is greatly appreciated.
Melissa Terman
Brian and Jenny Blanthorn
Re: Problem Slicing Pattern Bar
Melissa wrote:As I'm slicing through a pattern bar, when I get to the very end of the slice it cleaves and ruins the cut (and my need for perfection). I'm slicing on a MK 101. The water feed is working and everything appears fine, until I get to the very end and snap.
Hand held or auto feed
Try slowing down as U get 2 the end
Saw more than one at once
Tape scrap sheet glass on the back of it
Encase in plaster
Post by Tony Smith »
Melissa,
As you get very close to the end of the cut, the glass becomes very thin and will snap with the slightest force. So, when you get close to the end of the cut, slow way down and don't push so hard. Let the blade grind its way through the last bit of glass.
Lisa Allen
Post by Lisa Allen »
Melissa, along with going more slowly yo can also try to increase the thickness of your slices a bit. I find that the thicker the slices, the less breakage I have.
Tony Smith wrote:Melissa,
Lisa Allen
http://www.lisa-allen.com
Amy Schleif-Mohr
Post by Amy Schleif-Mohr »
I'm having trouble visualizing this, can you try to explain it better.
Amy
Mark Kemp
Post by Mark Kemp »
Can you cut a short way into the far side of the bar, then flip it and make the main cut? I haven't cut pattern bars, but I've used this method with wood and with single-thickness glass to prevent breakout.
jim simmons
Post by jim simmons »
I have found that the best way for me, is to back the pattern bar with another piece of glass or ceramic.javascript:emoticon(':idea:')
Idea
Jim
