Tack Fusing noodles during slump cycle
Shari L LeFever
Post by Shari L LeFever »
Hi, I am using spectrum 96, have done 2 firings. The first was the blank, the second to place small geometric tiles in design. I plan to decorate on top of this design using noodles I have cut in half and formed into shapes using a torch. My question is, If I want the noodles to retain their shape and not go to a full fuse (technically tack fuse I guess) can I "fuse" them and slump at the same time?
Shari
PattyJohnson
Post by PattyJohnson »
Hi Shari,
yes you can tack them during a slump...I usually apply a little glue to keep them from moving.
http://plj.alternateversion.com/images/ ... SERIES.JPG[/img]
not sure if the pic worked
Take care...Patty Johnson
http://www.pljglassart.com
Judith Andre
Post by Judith Andre »
Patty...Where do you get your iron plate holders? I like the simplicity of them.
Judith
Judith
Nancy Juhasz
Post by Nancy Juhasz »
Question here. When I slump can I tack fuse 1/8 in glass to the base of what I am slumping or draping? I was under the impression that the tack fuse had to be a separate step. It would be wonderful if I could eliminate one firing.
Nanc
