Bullseye ThinFire instead of kilm wash on metal molds
Marie Duncan
Post by Marie Duncan »
:) I am completely new at this. Just finished reading Brad Walker book. It is great. Want to share with anyone interested that I have had good results in using a piece of ThinFire between glass and stainless steel molds. This makes it possible to use these molds for draping without using kilnwash. Which I find to be a big pain. Just cut the ThinFire slightly larger than the piece of glass.
Marie
charlie
Post by charlie »
draping means outside? that's what your supposed to do with steel molds. or do you mean inside the form? does the paper fold up and leave marks on the glass?
Marie Duncan
ThinFire on metal molds
Yes I mean on the outside of mold. ThinFire is a light weight shelf paper and it replaces the need for a kilm wash on the metal mold. I find it time consumming and difficult to get kilm wash to stick to the metal and this is a very quick and satisfactory solution. I have not seen anything mentioned in articles or have not found anyone else that has tried this method.
Marie
jim simmons
Post by jim simmons »
charlie wrote:draping means outside? that's what your supposed to do with steel molds. or do you mean inside the form? does the paper fold up and leave marks on the glass?
works just fine. No marks that I can see.
Jim
Marie Duncan
Sorry Charlie I didn't answer your question regarding the surface. It is very similar to kilm wash. No problem with folding. The paper appears to adhere to glass and follows through the melt. Washes off with warm water.
I have used S/S cheapie bowls purchased at grocery store. One is about 4 in dia. and the other about 8 in. Work great. Also used short former, but my problem with this is not related to the paper. I have a problem catching before it melts too far and is not attractive. Got any suggestions?
Marie
Washington State
charlie
Post by charlie »
Marie Duncan wrote:Sorry Charlie I didn't answer your question regarding the surface. It is very similar to kilm wash. No problem with folding. The paper appears to adhere to glass and follows through the melt. Washes off with warm water.
Marie
Washington State
thanks. i have some bowls i got at goodwill that have really steep sides. i've used them for small things so that the glass only hits the bottom and a little on the sides.
catch it sooner? :)
you have to look more often. a lower temp for longer will do the same as a higher temp for shorter. lower your top temp and it won't move as fast. you also have to learn how much below your top temp to stop it as the kiln will hold a lot of heat and only go down slowly (for a brick kiln), or use crash cooling to get it below 1100 or so so make it stop moving when you want it to.
Kaye
Post by Kaye »
Thanks, Marie. I've wondered about using thinfire over a mold, but haven't been brave enough to try it!
Kaye
Lia Howe
Kiln-forming discussion
Post by Lia Howe »
I always use kiln wash on my stainless with no problems. Mix it with methyl hydrate instead of water. I looks like a thin coat on the stainless. After you have covered all the surfaces you set the methyl hydrate om fire. *****Make sure all containers of methyl hydrate are closed and put away before you burn the mold.*******
After the flame , which is invisible, burns off you will see the kiln wash. I have never had a problem. Works great for me. It's quick, easy, and I get to play with fire.Lia
SAReed
Re: Kiln-forming discussion
Post by SAReed »
Lia Howe wrote:I always use kiln wash on my stainless with no problems. Mix it with methyl hydrate instead of water. I looks like a thin coat on the stainless. After you have covered all the surfaces you set the methyl hydrate om fire. *****Make sure all containers of methyl hydrate are closed and put away before you burn the mold.*******
Sounds like fun! But I almost burned down my kitchen steaming vegetables...maybe I shouldn't try it. :doubt:
Stacey
PDXBarbara
Post by PDXBarbara »
ooo. love the setting on fire technique.. (hey is there anyone on THIS board who wouldn't love it??)
So, 1) is mythyl hydrate some kind of alcohol?
2) Does the wash/methyl hydrate mix adhere to the SS without heating? Is it sticky or something??
chemistreeeeflunkeeeeegirl.
Barbara Bader
Lia Howe
Post by Lia Howe »
Methyl Hydrate is an alcohol based product,for those of us who live in colder climates it is closly related to gasline antifreeze.
When mixed with kiln wash (I use Bullseye) it lookes like thin milk. No you don't need to heat the mold to get it to stick. As you brush on the mixture it will pool at the base of the mold. Just make sure that ALL surfaces are covered with a thin coating of the wash. it will look like you have not put much on but when you fire (as in flame) the surface you will see a great coating of kiln wash.Lia
PDXBarbara
Thanks, Lia... 1 more question...
when you burn it... fumes toxic?
BB
Barbara Bader
PDXBarbara (Bader) wrote:Thanks, Lia... 1 more question...
BB
Methyl hydrate is also know as methanol or wood alcohol. It's highly flammable, and (according to the MSDS) "toxic by inhalation, ingestion, or skin absorption." If you use it, then by all means take the proper safety precautions.
http://ptcl.chem.ox.ac.uk/MSDS/ME/methyl_alcohol.html
http://www.2spi.com/catalog/msds/msds02523.html
charlie
Post by charlie »
i wonder if cheap brandy would be a good substitute? :)
Lia Howe
Post by Lia Howe »
Cheap Brandy is better for hot toddys. You know warm milk and brandy. My father gave it to me as a baby to help with teething. I know, that can explain sooooo much about me now.
Oh Ya to answer your questions. YES YES YESS!!!!! Safety,Safety and lots of common sense is needed in the studio. Methly Hdrate is a toxic substance. BEFORE you use it learn all you can about how to handle this liquid SAFELY!!!LIA
LDGlass
Post by LDGlass »
I've used thinfire over a bracelet mold and it worked fine -- no marks. :D
Laura
