E-6000 glue trouble for 1st time - WarmGlass.com
Leslie Ihde
Postby Leslie Ihde » Mon Oct 13, 2003 12:00 pm
Hello Glassies,
I have been happily using E6000 silicon glue for ages and nary a trouble. Then the other day, for the first time, a gallery called me and told me that the mirror which is glued to my fused glass frame developed a small crack. I thought it was a fluke- it had happened once yrs ago with a ceramic mirror. Maybe the glue pulled the glass and started a teeny run, or something. Then today, I saw it had happened on a second mirror in my home! Now I'm upset. The only think I think I did differently recently was use small plastic clamps when I glued the mirror. What should I do?
Can I get the mirror off the glass and salvage the frame somehow- perhaps by heating it to 500 degrees or so?
Can I slice the mirror off somehow?
Should I use silicon instead of E6000?
Any experienced help would be most gratefully appreciated- I have 3 shows coming up!!!
Leslie
Leslie Ihde
Turning Point Studio
Vestal, New York
Geri Comstock
Postby Geri Comstock » Mon Oct 13, 2003 12:18 pm
There are two ways of removing the glue from a mirror that I've been successful with. One is to soak it in a solvent that will dissolve the glue. The other is to burn it off, which smells horrible and probably creates lots of nasty toxic fumes. Burnning off the glue on mirrors has been more successful for me. I take it to 750 and hold for 5 minutes to just get the glue to let go. It doesn't completely burn off at that temp, though.
I found that my mirrors were cracking when I was storing them flat instead of on their edge. Never did figure out why this was the case, but that seemed to be the pattern.
Geri
Leslie Ihde
Postby Leslie Ihde » Mon Oct 13, 2003 2:37 pm
Geri-
That sounds good. Any discoloration to the fused mirror frame? Also, you prefer burning off, which I think will be what I would do. But what would a solvent be and does the solvent hurt the glass? I have a call into the company that makes E-6000, so that may give me additional info.
Thanks for taking the time to post.
Leslie (excited and scared now that things are happening in glass art for me)
Leslie Ihde
Vestal, New York
BobbieMatus
Postby BobbieMatus » Mon Oct 13, 2003 3:06 pm
Leslie, let me know what the company says. I have been using e6000 to glue my mirrors also. Haven't had any problems but would like to know what the company tells ya
Bobbie
Leslie Ihde
Postby Leslie Ihde » Mon Oct 13, 2003 3:11 pm
The company says the solvent is acetone, but it doesn't dissolve it, just soften it. Doesn't acetone dull glass? anyone know?
Leslie Ihde
Vestal, New York
charlie
Postby charlie » Mon Oct 13, 2003 3:22 pm
Leslie Ihde wrote:The company says the solvent is acetone, but it doesn't dissolve it, just soften it. Doesn't acetone dull glass? anyone know?
no, but it will remove the paint off the back of the mirror.
Geri Comstock
Postby Geri Comstock » Mon Oct 13, 2003 3:33 pm
I think I've used a different solvent from acetone but can't recall what it was. I know that Terry Ow-Wing has posted about it for removing posts, etc. that have been glued onto glass jewelry...perhaps a search for her posts would reveal what it is. The glue has to soak for several days and it leaves a gummy mess. The solvent evaporates and is highly flammable so it's best to put it in a closed glass container. Most mirrors won't fit into such a container which is why I've always burnt them off.
If you fire longer and hotter you can pretty much burn the glue off. I think I've taken mine to 850 and held it for quite a while, but OOOHHHH what a stench.
You'll have to experiment with this to see what happens to your glass.
Good luck -
Geri
charlie
Postby charlie » Mon Oct 13, 2003 3:38 pm
Geri Comstock wrote:I think I've used a different solvent from acetone but can't recall what it was. I know that Terry Ow-Wing has posted about it for removing posts, etc. that have been glued onto glass jewelry...perhaps a search for her posts would reveal what it is. The glue has to soak for several days and it leaves a gummy mess. The solvent evaporates and is highly flammable so it's best to put it in a closed glass container. Most mirrors won't fit into such a container which is why I've always burnt them off.
Good luck -
Geri
it's a mirror. one can't fire mirror without losing the mirror part of the mirror. one is left with a piece of float glass.
Leslie Ihde
Postby Leslie Ihde » Mon Oct 13, 2003 4:32 pm
Thanks Geri, Charlie.
I'll go with the firing technique and see how it works. The mirror glass is history, anyway, since it's what cracked. I'm just trying to salvage the frame I made.
Leslie
Leslie Ihde
Vestal, New York
Carolyn Ledbetter
Postby Carolyn Ledbetter » Mon Oct 13, 2003 6:26 pm
One thing to consider is that E-6000 shrinks (into a thin layer) as it dries. For example, if you use it to glue just a thin border around the edges of something into a frame, it will try to stretch the glass as it dries. This usually results in a crack. For this type of application silicone seems to work best since it has some "give".
If you figure out an effective method of removing dried E-6000, please let me know. I too have a few failed projects.
Greg Rawls
Postby Greg Rawls » Mon Oct 13, 2003 6:40 pm
Doesn't silicon turn yellow over time? Never seen this, but heard it happens.
Greg
Terry Ow-Wing
Postby Terry Ow-Wing » Mon Oct 13, 2003 8:59 pm
.....Terry Ow-Wing has posted about it for removing posts, ...
it's me. I usually use something like a baking pan /turkey plan , use laquer thinner, close the top and leave in the garage for a day or so. For small jewelry finings I just use a glass jar and leave the findings in there. I may give it a shake or two once in awhile. For me it seems the least amount of work.
Good luck - Terry O.
Terry Ow-Wing Designs
http://GlassArt.weebly.com
Leslie Ihde
Postby Leslie Ihde » Mon Oct 13, 2003 9:07 pm
Terry,
Is laquer thinner the same as paint thinner? Would you try your techinque with a large piece if you had a big enough pan?
Leslie
Leslie Ihde
Vestal, New York
Postby rosanna gusler » Tue Oct 14, 2003 7:28 am
paint thinner is usually mineral spirits. laquer thinner is a mix of acetone and other solvents. acetone is acetone. i work with all these daily and i would suggest burning off the glue. it will be cheaper and safer. rosanna
Terry Ow-Wing
Postby Terry Ow-Wing » Tue Oct 14, 2003 12:46 pm
yes - I have 20 x 15" mirrors and have used this technique several times.
-Terry O.
Leslie Ihde wrote:Terry,
Leslie
Pamela B.
Postby Pamela B. » Tue Oct 14, 2003 7:23 pm
Very timely. I had a picture frame which was glued to a lucite stand develop a crack in both the lucite and the glass. E-6000. I've had this happen before with both mirrors and picture frames and attributed it to being knocked around although I wrap everything in bubble wrap whenever I move it.
To salvage the frame, I simply lay it glass-down on the top of my kiln and when the E-6000 softens, I pry the two apart. I use a citrus-based solvent to get rid of the E-6000, refuse the glass frame onto a piece of thin and glue it onto another lucite frame. No more will I use E-6000, though.
Pam
BobbieMatus
Postby BobbieMatus » Tue Oct 14, 2003 8:15 pm
If you will no longer use the e-6000, what will you use in it's place. just curious because I have been using the e6000 to glue my mirrors to fused glass.
Bobbie
Lynne Chappell
Postby Lynne Chappell » Wed Oct 15, 2003 1:35 am
Just a suggestion, if you decide to use silicone to glue your mirrors, be sure to get a "neutral cure" silicone as the regular stuff will eat the silvering if it comes in contact with it. Not right away, weeks or months later.
Pamela B.
Postby Pamela B. » Wed Oct 15, 2003 10:26 am
Most likely a five-minute epoxy.
Pam
Bobbie<
Barbara Muth
Postby Barbara Muth » Wed Oct 15, 2003 11:43 am
Leslie, I recommend using silicone for glass to glass (or glass to acrylic) bonds. The silicone has give to it, which means that the bond is less likely to break when jarred. Definitely go for the "neutral cure" that Lynne recommends if you are attaching mirrors. I have had numerous E6000 failures, but never a one with silicone. Just make sure it gets its 24 hours to cure. And btw, I use the GE brand silicone and it has never yellowed on me.
Barbara
Barbara
LATEST GLASS
Users browsing this forum: No registered users and 54 guests
