Granite Irid - WarmGlass.com
Granite Irid
fun5oh
Granite Irid
Postby fun5oh » Mon Dec 22, 2003 12:47 pm
What side of the glass is the irid coating on spectrum granite clear?
Robin :)
Postby Tony Smith » Mon Dec 22, 2003 12:49 pm
the rough side
tony
fun5oh
Postby fun5oh » Mon Dec 22, 2003 1:01 pm
Thanks Tony!
So then if I want to save the irid coating ( regular spectrum ) I should fire with the textured side facing my kiln shelf? How does this affect the texture at full fuse?
Robin :)
Tony Serviente
Postby Tony Serviente » Mon Dec 22, 2003 1:24 pm
The texture will be gone, replaced with the texture of whatever you're firing on.
Mark Kemp
Postby Mark Kemp » Tue Dec 23, 2003 1:18 am
Tony Smith wrote:the rough side
tony
Are you sure about that Tony? All the granite and textured glass I have has the irrid coating on the smooth side. I think at least some of it is Spectrum, but I can't swear to it at this point.
jim simmons
Postby jim simmons » Tue Dec 23, 2003 2:41 am
tony
yep, What Tony said.
jim
Postby Tony Smith » Tue Dec 23, 2003 7:18 am
tony
I'll have to dig some out to double-check, but the coarse surface is facing up coming through the lehr, so that's the only side that can get sprayed.
Lou_Ohio
Postby Lou_Ohio » Tue Dec 23, 2003 6:12 pm
I use this glass alot ... irid surface on the smooth side .
Will lose the texture on all glass at fusing tempertures .
Will usually lose the Irid surface at fusing temperture on Spectrum Glass.
Try System 96 or Bullseye to keep Irid surface).
Lou
Postby Tony Smith » Tue Dec 23, 2003 11:13 pm
Lou_Ohio wrote:I use this glass alot ... irid surface on the smooth side .
Lou
The word from Spectrum is that I was mistaken and that you are correct. The regular Spectrum granite, and all their textures for that matter, are iridized on the smooth side. I think my confusion came from the Black System 96 granite being iridized on the rough side and the clear System 96 granite from CBS having the dichroic coating on the rough side. I'm not sure about the clear System 96 granite, but will let you know.
TOny
Al Bray
Postby Al Bray » Wed Dec 24, 2003 1:47 pm
Just an FYI...
And what might confuse the matters worse in the future is that right now most (if not all) of the SYSTEM 96 Irrid glass is actually mfg by Urboros.
However....Spectrum just announced earlier this month that they are now manufacturing their own Hi-Fire Iridecent (starting with a black and clear standard and hopefully adding it to the full S96 color line). Will be interesting to see the pricing on the Spectrum offering as the Urboros....while wonderful glass, is a bit out of line pricing wise with the rest of the System 96 line (at retail cost anyway).
System 96 Hi-Fire Iridescents
Hi-Fire Iridescents with the Spectrum super smooth surface and unsurpassed cutability. We've achieved a satin-like gleam that is as beautiful before firing as it is after. Fire it Irid-side up, Irid-side down - or in between layers. Fire it over and over again. Or, don't fire it at all! The Hi-Fire Irid is a softer look -- very appealing for stained glass work too! We think it's the best Irid ever.
I/100SFS Hi-Fire Iridescent Clear
I/1009SF Hi-Fire Iridescent Black
Al Bray
Postby Al Bray » Wed Dec 24, 2003 1:49 pm
Just an FYI...
Postby Tony Smith » Wed Dec 24, 2003 2:14 pm
Yeah, actually that was the confusion. Uroboros puts their irid on the rough side, so the System 96 granite, both black and clear, have irid on the rough side (just confirmed by Kat).
Spectrum puts their irid on the smooth side, and the new System 96 glasses should have irid on the smooth side as well.
Postby DonMcClennen » Wed Dec 24, 2003 2:32 pm
I bought a few sheets of the new Hi fire Spectrum irid last week. I hav'nt used it yet but it looks promising. Price was less than the Uro irid.
Users browsing this forum: No registered users and 46 guests
cron
