cutting Duraboard - WarmGlass.com
cutting Duraboard
Marilyn Kaminski
cutting Duraboard
Postby Marilyn Kaminski » Thu Jan 08, 2004 10:07 am
I finally bit the bullet and bought some HD Duraboard to use as a shelf in the bottom of my Evenhead 2541. What should I use to cut it down to fit? Some type of saw ... but what type? And how much clearance should I leave on each side?
Will I need to make changes to my firing schedules once I start using the Duraboard instead of mullite shelves?
(I spent quite a bit of time studying the archive before buying this ... thanks to everyone who has contributed to that wealth of knowledge!)
Rigidizer and respirator in hand ...
Marilyn
Re: cutting Duraboard
Postby Bert Weiss » Thu Jan 08, 2004 10:56 am
Marilyn Kaminski wrote:I finally bit the bullet and bought some HD Duraboard to use as a shelf in the bottom of my Evenhead 2541. What should I use to cut it down to fit? Some type of saw ... but what type? And how much clearance should I leave on each side?
Marilyn
Marilyn
No need for a saw. Use a razor knife. You might need to adjust your heating schedules. It might require a longer soak to get the same work done, but it might not. The annealing should be the same.
Gale aka artistefem
Postby Gale aka artistefem » Thu Jan 08, 2004 11:47 am
Marilyn, depending on the thickness of the board, I use either a sharp razor knife or a very fine toothed hand saw - generic type that is kicking around most households and garages.
When the board is 2" or thicker, I like the saw better - it's easier to get a smooth edge and you can gently smooth the edges after you cut, with fine grit sandpaper.
Be sure to vacu' well and do a wet clean up with disposibles when you're done. Better safe than..............wondering about safety/health concerns.
Amy Schleif-Mohr
Postby Amy Schleif-Mohr » Thu Jan 08, 2004 1:23 pm
I have found that a dry wall saw works the best. Then I just smooth the edge down with my hand.
Amy
Users browsing this forum: No registered users and 50 guests
