Weiss Judaica
Judd
Weiss Judaica
Post by Judd »
I'm looking at buying Menorah candle cups (silver colored, probably aluminum and very affordable) from Weiss Judaica. Has anyone had experience with the company? I tried Rite Lite, but saw only brass (and a much higher price). I placed this here because the employee of Weiss said the hole on the bottom of the cup was not threaded, whereas the Rite Lite's were. My thought was to force a threaded rod in the hole, then attach it to my glass - or would I be better off just getting the threaded hole cups from Rite Lite?
In case that was confusing:
1) Weiss or Rite Lite?
2) Threaded or non-threaded hole?
Thanks.
Re: Weiss Judaica
Post by rosanna gusler »
easy enough to tap threads into aluminum. rosanna
Judd
Re: Weiss Judaica
Post by Judd »
My thoughts too. Hmmmm...
Bharr
Re: Weiss Judaica
Post by Bharr »
Weiss is very old and reliable. I glue my candle cups on. I use 3M Scotch weld DP-190 2 part epoxy. Pricey, but will NEVER come apart.
smallbitz
Re: Weiss Judaica
Post by smallbitz »
Judd wrote:I'm looking at buying Menorah candle cups (silver colored, probably aluminum and very affordable) from Weiss Judaica. Has anyone had experience with the company? I tried Rite Lite, but saw only brass (and a much higher price). I placed this here because the employee of Weiss said the hole on the bottom of the cup was not threaded, whereas the Rite Lite's were. My thought was to force a threaded rod in the hole, then attach it to my glass - or would I be better off just getting the threaded hole cups from Rite Lite?
Thanks.
At the risk of sounding dense, exactly how (and what kind of) threaded rod do I force through the hole in the bottom of the cup? Then do I drill a small hole into the glass to accomodate the threaded rod? Just can't quite visualize it. Or is it better to just glue them in place? Thanks!
SB
