I searched the old posts, and it seems Weiss is the best place to get menorah candle cups. What I'm not sure about is the best way to attach them to the menorah...I saw one recent post that mentioned forcing a threaded rod through the hole at the bottom of the cup, but I have no idea where to get a threaded rod - suggestions. If I go that route, do I drill a hole in the menorah to accept the thread? Hmm. I guess my questions are:
1. Is Weiss the best place to get menorah candle cups?
2. How do I go about making them threaded (or do I need to)?
3. Where do I get the threaded rod?
As always, thanks!!
SB
Menorah candle cups
Re: Menorah candle cups
1. get the cups first. Weiss is a good source. There aren't that many that I've found.
2. THEN figure out how to attach. Without the cups, you won't know if they've got a hole or not. Threaded rods are just screws without tops. You can buy them at Home Depot in the bin with the long metal stuff. Sometimes they're called all thread. If you do that you'll have to cut them to size with a cut-off wheel on a dremel (or a miter saw would be better). Or you can glue them. Lots on the archives on metal to glass glue.
--Ralph Waldo Emerson
Cheryl,
Thanks. I know exactly what you mean by the threaded rods (now!). I think I was having a brain fart. I do have some great glass to metal glue that I used for a kitchen hardware to glass commission. It was an epoxy of some sort, I think Devcon. It worked great! I'll order the cups from Weiss.
