Fire pit glass? - WarmGlass.com
Fire pit glass?
Dianne Van de Carr
Fire pit glass?
Postby Dianne Van de Carr » Mon Nov 05, 2012 4:35 pm
Is it possible to use broken fusible shards of glass in a fire pit?
Dianne
Re: Fire pit glass?
Postby rosanna gusler » Mon Nov 05, 2012 5:18 pm
yep. glass is glass. rosanna
bob proulx
Re: Fire pit glass?
Postby bob proulx » Mon Nov 05, 2012 5:28 pm
I have done it and it works fine, I am assuming you are talking about a gas fire pit. I usually bring the up glass to a full fuse first to round up the edges so you don't cut yourself every time you have to clean it.
Judd
Re: Fire pit glass?
Postby Judd » Tue Nov 06, 2012 12:34 pm
Dianne, like how? A wood fired down daft barrel or a fire pit for pottery? If you mean that, then that's usually a very low temp - like 1000 F to 1200 F, which is too low temp for glass fusing.
Dianne Van de Carr
Re: Fire pit glass?
Postby Dianne Van de Carr » Wed Nov 07, 2012 1:33 am
The fire pit is propane fired and huge. 2 x 6 feet burner. After it was built my friend calculated how much glass would be needed. He thinks about 250 pounds. I suggested contacting a Shower Door replacement company for tempered glass. Then as we brainstormed, I got the idea of using my scrap glass for a decorative element.
Thanks for all your replies,
Dianne
Judd
Re: Fire pit glass?
Postby Judd » Thu Nov 08, 2012 12:59 pm
Dianne,
You're fusing? You're not mixing different glasses from different companies, are you? If the glass is all the same COE, from the same company, you will have better results. If it's a mixture of glasses from different companies - you're probably screwed. We usually use electric, computerized kilns because you don't have to babysit you kiln. People do use gas kilns, but it sounds like too much work for me.
David Jenkins
Re: Fire pit glass?
Postby David Jenkins » Thu Nov 08, 2012 1:09 pm
[Ooops! Meant to direct to @Judd. :oops: ]
I think she's talking about an outdoor fire pit (aka "outdoor fireplace") that uses propane as fuel, rather than wood. Such pits are frequently populated with lava rock which is then often topped off with [expensive] decorative glass beads.
Dave Jenkins
Glass at Harbor Gates
Cypress, TX
Judd
Re: Fire pit glass?
Postby Judd » Thu Nov 08, 2012 1:13 pm
A decorative element! OH! Not actual glass work. Check!
Re: Fire pit glass?
Postby Morganica » Thu Nov 08, 2012 2:03 pm
Sure...although they're liable to look like jagged fusing glass scrap if you pour them straight into the pit. If you fire them hot first, they'll round up and look more like the stuff you buy.
Users browsing this forum: No registered users and 7 guests
