annealing 96 question - WarmGlass.com
stef
Postby stef » Fri Jan 11, 2013 5:39 pm
hypothetically , if a project was not sufficiently annealed, is it possible to reheat to anneal temp and redo the anneal ?
thanks Stef
Joe Wokovich
Re: annealing 96 question
Postby Joe Wokovich » Fri Jan 11, 2013 5:47 pm
Shouldn't be a problem. Just go really slow on the heat up. Then use your regular schedule for finishing the firing.
Joe
“If you tell me, I will forget.
If you show me, I will remember.
If you let me do it, I will understand."
And then tomorrow I can start all over again
stef
Postby stef » Fri Jan 11, 2013 6:01 pm
25 degreesC (77F ) be slow enough?
Rick Wilton
Postby Rick Wilton » Fri Jan 11, 2013 6:37 pm
how big? How thick? full fused or tack fused?
No easy answer to that question.
Good Luck
Rick Wilton
Postby twin vision glass » Fri Jan 11, 2013 7:00 pm
Don't forget to go above anneal and hold for abit before you go back down to anneal to make sure the inside of glass is same temp for even anneal. (I have taken a larger piece back up to 1100 F. but because it was an inch thick I went toooo quickly and broke it, THEN went 50 deg per hour back up to full fuse and it all went back together so nicley), so slow down to 50 deg. per hour just like suggested above and it will help to even heat everything as well. Les
stef
Postby stef » Sat Jan 12, 2013 3:14 am
1/2"(12mm) thick,
12" ( 30cm) round.
Slump ( into sand) prog was:
Farenheit;
300/1000/20
570/1380/60
AFAP/1000/45
75/970/90
75/900/15
130/750/10
Celcius;
150/540/20
300/750/60
AFAP/540/45
25/520/90
25/485/15
55/400/10
I thought this ramp down would be slow enough to anneal but seems not.
2 of the discs seem fine, 1 has broken through the centre while I was scrubbing the sand off it, 1 is still in the kiln on the sand so I thought I might try taking it up again and adding an extra hour soak at 900 (485)
So the questions are ...
how fast to go up ( to 1000(540) )
and am I ramping down slow enough
Am I soaking at the right temps??
cheers Stef
Barb R
Postby Barb R » Sun Jan 13, 2013 6:56 pm
Here are the suggested firing and annealing recommendations from System 96:
http://www.system96.com/Pages/ThickFiringGuideF.html
I would follow the 1 inch recommendation since you are firing on the sand bed.
Barb
stef
Postby stef » Mon Jan 14, 2013 7:13 am
thanks Barb,
that makes sense... my thinking was stuck in a groove... I thought I had the correct firing prog from when I did this about a year ago but I must have lost the right page with the longer program from my folder. It just didn't connect with my brain that the anneal soak was too short.
(Note to self; ... tidy folder & studio.)
Now I need to re anneal the discs which haven't broken.
Any idea on how fast/what temp I should reheat at ??
Any advice from anyone is much appreciated.
stef
I have tried to upload a photo of what I am doing but It tells me that the file is invalid... What does that mean?
I'm not very clever with computers!
Barb R
Postby Barb R » Mon Jan 14, 2013 1:29 pm
I'd go up at 50 dph (or slower) to 1000 degrees, then come back down through the recommended annealing schedule... Good Luck!
Barb
Users browsing this forum: No registered users and 36 guests
cron
