Hello,
I forgot to ask another question
can this raku clay be use for a sculpture & such? Indoors/outdoors
Raku Clay
You can use it outside provided you glaze it first. The glaze needs to be heavy and you could just use a gloss coating to retain the clay color. Otherwise, like Ron said, it will soak up the water.
Be sure to glaze inside the container as well if there is a chance water will get in. Raku clay is formulated to withstand more thermal shock than other clay since the Raku firing process is quite "abusive" or intense. When I fire Raku clay, I also may place it quickly once its reached the high temp, into various things like sawdust, old car oil... and then it gets dumped into water.
Its a very "hands-on" experience worth checking out. Just make sure you make lots of things and get attached to none of them untill after the process. You will loose a few or the color may not come out right for some of the items.
