architectural glass mounting ... rubber/epoxy? - WarmGlass.com
tonyroberts
Postby tonyroberts » Fri Nov 20, 2015 9:31 am
Hi all... good to see you all still here!
I wish to mount thick cast glass - like dalles, but glass cast and stained in my kilns, 15-25mm thick - in a resilient framework, able to withstand occasional vibration. The Liverpool Metropolitan Cathedral has its acres of glass set in a sort of black rubbery matrix, which would be perfect! But - what is it? It looks rather like the rubbery stuff that they lay down under the play equipment in children's playgrounds.
Re: architectural glass mounting ... rubber/epoxy?
Postby DonMcClennen » Fri Nov 20, 2015 11:58 am
I'm thinking it might be a form of a material like Thiokol which is black and is/was used to install car windshields... flexible and very strong..
tonyroberts
Postby tonyroberts » Fri Nov 20, 2015 3:25 pm
Thanks.... but no, this stuff is two-three inches deep, more like the dimensions of the concrete in modern architectural stained glass panels.
??? Tony
Postby Marty » Fri Nov 20, 2015 6:48 pm
Postby Bert Weiss » Sat Nov 21, 2015 11:44 am
You can get silicone epoxy that comes in 2 parts. Some are clear and others not.
I am a fan of using L screws. They are minimally visible, and will not let the load fall off.
Postby Valerie Adams » Sat Nov 21, 2015 12:23 pm
You can get black flexible grout but that's assuming the glass is mounted to something I believe.
Users browsing this forum: No registered users and 12 guests
