firing surface
firing surface
just curious, how many fire fused glass projects on 1/8th inch fiber paper or directly on a kiln- washed shelf are there advantages , disadvantages? I've noticed the pieces fused on fiber paper are generally cleaner and cool better. just wondering what y'all find better. thanks
At just the right fusing temp (I don't have notes in front of me) and by not firing hotter than necessary, I get 2 or 3 firings on a sheet of 1/16 inch fiber paper.
You can get a few more if you sift a dry diatamaceous earth/plaster mix evenly on the paper before firing. By pressing the glass slightly onto the well dusted paper and being careful not to kick up any dust, you can get a very smooth bottom surface and fatal bubbles are less likely.
Firing on a kiln-shelf that is only kiln-washed can produce large bubbles between the glass and the shelf. They are not good bubbles.
I prefer at least thinfire paper to help prevent those big bubbles.
I use thin fire paper exclusively. Haven't washed a shelf in 10 years. For my situation it is much more economical to use paper. Problems I had with wash was the required manhandling of the shelves, and the time to prep. Other issue was that if it was not done properly, the glass stuck and I lost a piece and the shelf was pockmarked too. And then there is the bubble issue...Disadvantage of paper is the clean up. It can't be treated casually. I use a Hepa vaccuum cleaner as well as a respirator. Some may cite the cost of the paper as another disadvantage, but considering the time saved it is cheaper for me.
We use fiber shelves, mostly, with a couple of instances where a smoother surface is needed, and the shelf is mullite or RS100. Only thing I have to adjust is the firing time. Glass on fiber fires hotter than on ceramic, so firing time/temp is less. So we always have different firing schedules for either board, AND for each kiln. There is a long firing list posted in the studio for each product line. Once you work it out, it's fine, but the challenge is getting to that point. - Barbara
