Have been making some tests with really slow fusings, long bubble squeezes and top firing, to try and minimize bubbles.
Test pieces are small, square 4 1/4", round 9cm diameter (slightly less than 4"), this is in preparation for larger pieces.
Tests 1 & 2: 2 layers of Tekta 1/8", 1x smooth side in, 1x bumpy side in. Still more bubbles than I'd like.
Test 3: 1x Tekta 1/8" covered with one single layer of coarse frit (number 3 size).
Arranged the frit carefully, tightly close to each other but in a single layer - took a while to do this
Thinking the hole was due either to a gap between the kiln shelf and the glass, or to total volume of glass not adding to 1/4", tried again same setting on a perfectly straight shelf. Same result, same big hole...again no bubbles on the remaining border.
So, it seems to me that I need more frit (would this be the equivalent in weight to the tekta piece?) to achieve a 1/4" thickness at full fuse. Tekta sheet does come in 4mm and 6mm thickness, but the intention is to use colored glass capped with clear once tests are done.
Since I have to pile the frit higher, could someone kindly advise me if is it better to use size 3 for this, or the extra large size 5 to achieve the most bubble free result?
BE catalog says:
03 - coarse ranges from 2.7 to 5.2 mm (6mm is just under 1/4")
05 - extra large ranges from 5.2 to 30 mm (25.4mm = 1").
From this, 05 seems pretty large, at least some of the pieces, but I have never seen it.
Hoping for your help,
Many thanks as always, seachange
