Mica fusing
Mica fusing
I fuse mica between two pieces of glass, to avoid mica sticking to the clear glass cap, I cover the mica with clear glass powder or clear transparent enamel. I always get cloudy appearance after fusing
Re: Mica fusing
The clear powder is causing the cloudy appearance. I don't understand your comment about keeping the mica from sticking to the clear cap. What are you trying to achieve?
Dana W
Dana W
Re: Mica fusing
you don't need to cover the mica with anything. I've had good success even doing the mica on top and not capping at all. just depends on the look you are going for.
Re: Mica fusing
Dana W
what i ment that when fusing clear enamel on the top of mica the enamel turn to be cloudy not crystal clear as it should be
Re: Mica fusing
lorimendenhall
I am trying to fuse a pendant with mica inside, part of the mica stick to the clear cap and the shape of the mica drawing does not stay as one unit
