Primo Primer Muck - WarmGlass.com
Primo Primer Muck
tgotch
Primo Primer Muck
Postby tgotch » Fri Oct 18, 2013 8:15 am
I have been testing Primo Primer, and like the results. One thing I have noticed though, is the primer tends to "muck" up in my storage container. I mix it in an old Gatorade bottle, put the marbles in it, and shake it up well. If it sits for longer than a day, the primer separates from the water a bit, and mucks up in the bottom.
Any way to avoid this?
Re: Primo Primer Muck
Postby Valerie Adams » Fri Oct 18, 2013 9:51 am
I keep Bullseye's primer pre-mixed in a bottle too and it also separates. I just shake well before using. The ingredients are too heavy to stay suspended in water.
Postby Bert Weiss » Sun Oct 20, 2013 3:15 pm
There is a primary difference between Bullseye primer and Primo primer. In Bullseye the binder is kaolin EPK clay. In Primo the binder is an organic gum. These materials behave differently in the way they mix and disperse.
jim simmons
Postby jim simmons » Fri Oct 25, 2013 12:40 pm
Yea, but you can't avoid the separation
Jim
Bert Weiss wrote:There is a primary difference between Bullseye primer and Primo primer. In Bullseye the binder is kaolin EPK clay. In Primo the binder is an organic gum. These materials behave differently in the way they mix and disperse.
Postby Morganica » Fri Oct 25, 2013 4:58 pm
Bullseye primer separates just as nicely. I have both, side by side on a shelf, not much difference in appearance except for color.
Postby Bert Weiss » Sun Oct 27, 2013 10:25 am
Kaoilin based primers are easier to remix than gum based.
Return to “Newcomer Forum”
Users browsing this forum: No registered users and 3 guests
