Tac fuse for pebbles
I remembered from something that I cover a circle with pebbles then tac and slump.  I have one layer circle and covered it with pebbles.  Need suggestions for firing schedule - I don't want to loose the texture but I want the pebbles to most definately be attached.  Thanks
Re: Tac fuse for pebbles
wont work. glass will break on cool dowd. r.
				jim simmons
Glass pebbles or  rock pebbles?
Glass will work, rocks will not.
Jim
Jim
				Charlotte Kay
I think she means fused glass "pebbles" that you make from breaking up a pattern bar or pot melt. Kinda like frit balls.
I have used either the 2-layer or the 3-layer fusing schedules for a tack fuse on fusedglass.org Depends on how thick your base circle is and how thick your pebbles are. You want to use the thickest measurement in your calculations.
