Making a rainbow - WarmGlass.com
Making a rainbow
Jan de Jong
Making a rainbow
Postby Jan de Jong » Fri Jun 30, 2017 2:57 pm
Hello ! Is there a simple way to make a "rainbow" (half-circle) with 6-7 colours ? Jan de Jong
jim simmons
Re: Making a rainbow
Postby jim simmons » Fri Jun 30, 2017 3:58 pm
Sure.
cut a circle then cut it in half and layer different frits on it.
The other Jim
Jan de Jong
Postby Jan de Jong » Sun Jul 02, 2017 4:47 am
jim simmons wrote:Sure.
The other Jim
Thank you Jim ! Is there a way to do it with sheet glass (as I still did not work with frits and not have them). Is it possible with a saw ? Jan
Fiona Collins
Postby Fiona Collins » Sun Jul 02, 2017 7:29 am
Cut a half sheet of clear and butt against 1/2 sheet of first colour. Place your circle cutter in the middle of the join, score half circle on the colour sheet, adust length in 15mm, leave base as is, run second score. Replace colour sheet with second colour, score with same setting as previous, adjust length in 15mm ... rinse and repeat 4 times. Carefully run and break out each segment
Jan de Jong
Postby Jan de Jong » Wed Jul 05, 2017 5:00 am
@ Fiona Collins: Thank you ! Jan
Return to “Newcomer Forum”
Users browsing this forum: No registered users and 7 guests
