Tack fusing, but different
Jan de Jong
Post by Jan de Jong »
Hello, I did a full fuse with 2 layers Spectrum glass. After that full fuse I did a tack fuse with 2 layers on the first glass. Temp. 750 degrees Celsius. But the 2 layers had spread out, it look like a full fuse. Do you have to use a lower temp. by 4 layers ? Jan de Jong
Jan de Jong
Re: Tack fusing, but different
Sorry, perhaps placed in the wrong topic. Jan
Judd
Post by Judd »
No, posting here is fine.
How long did you hold at 750?
Jan de Jong
Judd wrote:No, posting here is fine.
For 10 minutes. Jan
Judd
Post by Judd »
Are you sure your thermocouple is reading correctly?
Whatever the case, maybe hit your target temp for only 5 minutes?
