Question about ceramic rope
Jan de Jong
Post by Jan de Jong »
Hello! When I use 1 - 1,5 mm ceramic rope between 4 layers of glass Full fuse, will it become brittle or can I use it later for another lower temp fusing ? Jan
jim simmons
Re: Question about ceramic rope
Post by jim simmons »
Could you please explain what you are trying to do?
That would help a lot
The other Jim
Jan de Jong
Hello ! I will try to explain. I want to make a necklace of cubics 1 x 1 x 1 cm , where the height will be a little more, as I take 4 layers of transparent glass.
For the holes I had the idea a 1 - 1,5 mm ceramic rope, using it the whole length for as many cubics as I can place on my kiln-plate. Full fuse them. Then I have to get a shiny gloss on ALL the sides. Is the rope still strong enough to hang it with the cubics between kiln stands to fire again ?? Sorry, more and more difficult for me to find the right words in English.
I hope it is clear. Jan de Jong
Post by Kevin Midgley »
use a kiln wash coated stainless steel welding rod. I don't think rope will hold up the weight.
Jan de Jong
@ Kevin + Jim: Thank you both !! Jan de Jong
