What did I do? Fusing gone bad!
I'm new to fusing and I'd like your opinion as to what I did wrong. I did a test strip with all of the glass and it looked like it was all compatible. I suspect that I'm reading my stressometer incorrectly. Can you tell by the break pattern?
Thanks for your help!
Deb
http://community.webshots.com/photo/109 ... 5052yGKyvU
Deb
That's the best example of incompatible glass I've seen in a while. Brad should use that picture in his next book.
The interesting thing to me are the sunken areas along the cracks in the transparent blue glass. Looks like the glass pulled apart before it was solid. I wonder if the glass was refired to heal the cracks?
Ron
Ron
Deb, I am new to fused glass too, and I'm trying my best to learn from other folks' mistakes so I can avoid them!
What kind of glass did you use? On my monitor it looks as if you capped the squares with clear. If you did cap, I'm wondering if perhaps it was a different sort of glass, and that might be the problem? Are the cracks in the cap, or in the squares?
Dayle Ann
Dayle Ann
I think Brock nailed it here. The clear cap is compatible with the light and dark blue squares, everything else is a different COE and not compatible with the clear.
So, what you did wrong was you mixed glasses. In the future, try to stick with the tested-compatible glasses. 90 COE with 90 COE, 96 COE with 96 COE, etc... And if you decide to mix manufacturers, even if they have the same advertised COE, you might want to test them like you did here to see if they are really compatible or not.
Thanks for all of your help!
It wasn't refired. That is the original fire.
I did cap it with clear. The clear is BE compatible. the light blue is Uroboros that was not listed as compatible, but I did a test strip and it turned out okay. The streaky blue was an unknown glass that I had and again tested it on the clear strip for compatability. (This is my "major malfunction!") It looks okay to me! I think I need to work on my reading! Then there is one piece of dicroic in each long row. The dicroic was listed as 90 and I didn't test it. Maybe I should have tested it too.
I must admit that I've done stained glass for many years, so I've got quite an inventory of untested glass. I'll probably experiment more than most beginners.
Thanks again!
Thanks again!
You may find all of that experimenting to be costly in terms of your time and lost glass. Two pieces of glass may test as marginally compatible with your base (the clear strip) but be far enough away from each other in compatibility that they should not mate in the kiln. For example: maybe one is 89 COE and the other 91 coe. Neither exhibits incompatibility with the clear, but fused with each other they mare likely to cause problems. Streaky glasses are even more likely to be incompatibilityculprits. Your best bet, when working with glasses like the ones you have, is to fuse them to themselves and not mix from one sheet to another. Or sell the glass and buy tested compatible glass like BE or System 96.deb.co wrote:Thanks for all of your help!
Thanks again!
And remember that the incompatibility, particularly when it isn't egregious, may not show up right away. I recently saw a piece in a show that exhibited a clear incompatibility crack. The piece was 3 years old and had been fine until it sat in a sunny window for a few days in this exposition.
Barbara
Deb,
If you are going to continue doing stained glass, move all that glass to a separate part of your studio.
Start buying COE 90 or 96; stick with one or the other and go from there. Keep them as far apart as possible. I still have glass from my stained glass days and do use it occasionally. Also, I do fire a lot of regular Spectrum glass but I keep it totally separate from my System 96. After a while I'm now able to tell the difference at a glance between regular Spectrum and 96, but I still keep them separated.
Judy
Judy
