resource list?
Post here if you need help on anything related to the board and how things work. If you need help on warm glass topics, use the Kiln-forming Discussion Board.
linn keller
resource list?
Post by linn keller »
brad,
is there still a resource list somewhere here on warmglass that lists sources for replacement elements, etc? saw a reference to it (from you) is response to older post, but can't find the resource list (or your post). did it go away with the hack? or am i imagining things? thanks,
linn
linn in deep deep south texas
Re: resource list?
Hi Linn, since you haven't received a reply to date I had a look. It's not a list of element suppliers but there are probably several mentioned in these posts:
http://www.warmglass.com/phpBB3/search. ... s&fid[0]=2
By now you've probably solved your problem anyway! Jen
