i've searched the archives for this but couldn't find a definitive answer....
i'm looking to buy a new kiln. i want a top loading kiln but i'm unsure about whether i should have a top element only or top and side elements. i do small fusing (inch or less) for jewellry and i am concerned the side elements will give a different result on the edge pieces as opposed to the inside area.
what do you think? i'm interested in the paragon fusion 7 as it uses 120v and has a top element only. have others had problems with even heating on this model?
tanks in advance,
diana
side and top elements
Re: side and top elements
Shastashasta wrote:i've searched the archives for this but couldn't find a definitive answer....
tanks in advance,
diana
I can see no advantage with side elements for doing flat small work. That said, I see no advantage to side elements in a kiln that is not significantly deeper than 12" and maybe not even then.
Top fire boy
diana - i have a small jenken 14" kiln with only a top element and a larger jen ken with both side and top elements, 15" deep - i have found that i have alot more cold spots in the small kiln, particularly at the edges of the shelf that screw with the look of my pieces, i get a much more consistent look with the larger kiln - which means less rework - so i would go for a kiln with both side and top elements to avoid excessive cold spot problems...shasta wrote:i've searched the archives for this but couldn't find a definitive answer....
tanks in advance,
diana
D
If I could design my own kiln, I would get one that lets me control the side elements. I've found that the side elements in my JenKen will seal the edges of my large pieces and trap air. The side elements do help even out the heat though. On larger pieces I like to use my Paragon with top element only. However, if you only plan to do small pieces even heat is probably more important. That said, small pieces are very forgiving and it really probably doesn't matter much. The most important thing is to make sure the kiln is not underpowered so you can fire fast and avoid devit. Marc
I'll bet those firebrick kilns are uneven because they have inadequate insulation on the roof. Sides maybe too. Fiber rules.Marc Demian wrote:If I could design my own kiln, I would get one that lets me control the side elements. I've found that the side elements in my JenKen will seal the edges of my large pieces and trap air. The side elements do help even out the heat though. On larger pieces I like to use my Paragon with top element only. However, if you only plan to do small pieces even heat is probably more important. That said, small pieces are very forgiving and it really probably doesn't matter much. The most important thing is to make sure the kiln is not underpowered so you can fire fast and avoid devit. Marc
