Glue-chipping fused
Glue-chipping fused
Can I glue-chip fused glass without causing stress that results in impending disaster? Has anyone tried this and had success? Thanks.
We usually just cover the stuff and go away for the night! This idea came up out of laziness.... I need to make some decorative glass for my studio entry that's obscuring and let's light in and I'm too lazy to build stained glass panels for each mullioned section (eight plus a transom). So I thought I'd fuse two pieces of nice clear with layers three and four tack fused in some nice decorative center dingbat.... and then, really obscure each corner with a glue-chipped design. (Then just silicone the units into the mullions, I didn't just say that! ) I figured as you mentioned, that with proper annealing it shouldn't be an issue.... and then I think back on that flying glass when the chipping process really starts going good! Eeek. I thought I'd better check with the pros first! I can just see all those little panels as they go bouncing off the ceiling.... talk about kitty entertainement!
On a related note, Barbara.... I'm half-thinking if these panels work okay to design some inexpensive kitchen cabinet door inserts that are fused and chipped. I also thought about offering matching tiles for each design. What do you think? Have you thought of adding kitchen cabinet inserts to your product line? Does the idea have possibilities or is it a real dawg?
