From a previous life, I have a couple of large spools of thin copper wire used in windings for electric motors. The wire has a lacquer coating that color-codes various wires based on temperature resistance. I'm wondering about using the wire between two sheets of glass: do you think the coating burn-off will leave a residue? I've used the wire in lampwork inclusions, but the lacquer burns off immediately in the flame, prior to my inserting it into the glass. I'm wondering if it will leave a deposit on the glass in the kiln, as temperatures will be considerably lower. Any ideas, suggestions, before I start experimenting?
fusing with copper wire
Beware of fumes and toxic dust. Burning it off in you kiln COULD harm your elements. Remember everything you put in your kiln ends up in some form on your elements. Steel wool will workbut it will take time. Also be aware that if your wire is the stuff I'm thinking it is, It can also burn . Firing in the kiln may make it brittle. I used thin copper wire to make hangers in some suncatchers. At a full fuse most of it became brittle.Yuck! Ruined some great pieces. I now use NicChrome. Works great.LIA
You could burn it before you use it. Always use protection. Unless you don't want to.I was picturing a person w/ a big bushy propane torch (maybe they are called roofing torches?) Anyway, they ar 15-20 at Harbor Frieght. Put on your respirator and drop the spool on a non-flamable surface like bricks or concrete and just torch it to red hot. If the concrete gets too hot, it may pop pieces off. If you get the copper too hot it may just vaporize or melt. You can do this outdoors.
j.
j.
