What's the best/recommended smoke alarm for a studio?
I don't have any kind of smoke alarm in my studio/converted garage right now and decided it was time to get with the program.
Thanks for your help.
Alecia
Smoke Alarms
Smoke Alarms
Alecia Helton
Wear Original Wonders!
Carrollton TX
Carrollton TX
call up your local building inspector to find out what's current in your area. in my area, the local code has all hardwired fire alarms, each linked to all the others, with both mains and battery backup. this way, if one goes off, they all go off, and they can then be wired into a security system that can be remotely monitored, and and also be hooked to a zoned sprinkler system.
Snoke Alarms
I guess my questions is, do I need a special kind of smoke alarm in the kiln area?
Alecia
Alecia
Alecia Helton
Carrollton TX
Carrollton TX
Yes I think a heat type would be better than a smoke type unless you mount it where you can easily turnit of while you are making smoke on purpose. If you do turn a detector off, I suggest you do some ritual like putting your car keys or the remote for the tv on it so that you don't leave it turned off.
j.
j.
