Oh Knowledgeable ones ...
I've been using fiberpaper to create textured, bas-relief tiles. I've developed some shapes/textures that I want to repeat consistently. Gil Reynolds book #2 talks about using paper with a rigidizer as a more permanent mold substrate. I have a few questions for you guys who use this technique.
1. I understand that for fiber blanket, you end up with about the half the thickness you start with. Will this also be true with fiber paper. So if I want 1/8" relief, I'll need to use 2 thicknesses of 1/8â€
Rigidized FiberPaper Substrate/Molds
i have not found much if any shrinkage with fiberpaper. i would use elmers and glue up my mold. then i would soak with rigidiser. it will not get all wet becuse the binder interferes. then dry and fire. soak again, dry and fire. kiln wash. use. the rigidiser will do a pretty good job at gluing it all together. i have one big ring mold made this way that i have been using for years. i do not prefire before rigidising because the fiber gets too soft and takes fingerprints and deforms for me. i think that it would tend to flatten as well. rosanna
Re: Rigidized FiberPaper Substrate/Molds
[quote="Jackie in Washington DC"]Oh Knowledgeable ones ...
Brian,
This looks like what I'm looking for. Let me make sure I understand you. 1. First I should put rigidizer on the fiberboard and fire it underneath(?) a mullite shelf so it won't warp.
2. Then I should paste up the fiberpaper and use some Bullseye kiln wash. -- looking back through earlier threads it looks like you're saying that Bullseye Kiln wash is a "bat" wash, correct?
3. Dry the paste/kiln wash. Rigizide & dry again.
4. Kiln wash again
5. Fire slow & low with a long soak (is the soak at fuse temps?)
Thanks very much for the suggestion.
4. Kiln wash again
Jackie
