Pot Melt Questions ??? - WarmGlass.com
Barbara Muth
Re: Pot Melt Questions ???
Postby Barbara Muth » Thu Jan 10, 2008 10:35 am
Lisa, how easy would it be to cut one of those sheets down? Have you tried it?
Barbara
LATEST GLASS
Tom White
Postby Tom White » Thu Jan 10, 2008 10:51 am
It should not be too hard to cut the expanded metal with a small to medium size pair of bolt cutters. Just cut across the sheet one junction at a time on a line at the long end of one of the diamond shaped openings. You may want to file or grind the cut edges to remove any sharp burs to make it easier (safer) to handle.
Best wishes,
Tom in Texas
Lisa Allen
Postby Lisa Allen » Thu Jan 10, 2008 1:15 pm
Barbara Muth wrote:Lisa, how easy would it be to cut one of those sheets down? Have you tried it?
I did try it, but I only have a large pair of tin snips and it was a no go. The stuff I'm getting is pretty heavy and rigid. Bolt cutters might do the trick, as Tom mentioned, but I don't have any.
Lisa Allen
http://www.lisa-allen.com
Laurie Saukko
Postby Laurie Saukko » Wed May 30, 2012 3:12 pm
If you know any sheet metal mechanics or heating contractors with their own shop they may be able to help you. :D
jim burchett
Postby jim burchett » Fri Jun 01, 2012 5:17 pm
If you cant find a shop to help you, you might try to bend the metal and move it back and forth until it breaks..you will need to have a vise or something to hold it rigidly across its length. A hacksaw or Tile saw would work as well.
Haydo
Postby Haydo » Sat Jun 02, 2012 8:45 am
When you think about it, this is so funny. It's like a think tank full of stoners. No offence, just a warning to other comedians. peace, haydo
Laurie Saukko
Postby Laurie Saukko » Wed Jun 13, 2012 5:37 pm
Any large metal fabrication shop will have a shear that can cut it, trust me this is what I do.
jim burchett
Postby jim burchett » Thu Jun 14, 2012 8:27 pm
I am missing the beginning of this thread.... :roll:
Users browsing this forum: No registered users and 25 guests
