Faulty glass? or faulty user? - WarmGlass.com
Barbara Muth
Re: Faulty glass? or faulty user?
Postby Barbara Muth » Sun Feb 17, 2008 8:37 pm
frizzygirl wrote:Hiya
Thanks Tony, sorry trying to be quick before my laptop battery dies.
Its 222C to 677C with a 30 min hold.
Then 333C to 777C with a 6min hold.
Regards
Tracey
that would be 400 dph to 1250F, hold 30
and then 600 dph to 1430 F, hold 6
So a couple of thoughts... If your base was one layer thick you were going to have problems with volume control at that high a temp. If you wanted to just tack the pieces together you could have done so at a lower temp, say around 1300 F or 700 C. You are ramping up way too fast which is why the piece thermal shocked. And that fast ramp will trap air in a piece as well. You need a bubble squeeze.
Instead try:
200 dph F to 1000F (111 dph C to 538C)
50 dph F to 1250F (28 dph C to 678C)
300 dph F to 1350, hold 15 (167 dph C to 732C)
and then anneal as recommended by your glass manufacturer.
Barbara
LATEST GLASS
Users browsing this forum: No registered users and 52 guests
