Tumbling Glass
Tumbling Glass
I'm curious if anyone has used a tumbler (rotary or vibratory) to cold work small pieces of glass?
What media did you use...how many grits did you work through...and how long did the whole process take?
Paul
Paul
TUMBLING GLASS
PAUL ARE YOU TRYING TO GET A HIGH POLISH OR ARE YOU TRYING FOR THE FROSTED BEACH GLASS LOOK ?
I HAVE BOTH ROTARY AND VIBRATORY BUT HAVE NOT DONE MUCH WITH GLASS. THE VIBRATORY WILL BE MUCH FASTER FOR WHATEVER. LET ME KNOW WHAT LOOK YOU ARE WORKING FOR AND WILL SEE IF I CAN HELP. CAROLE....S.C.
Re: Tumbling Glass
There is a lot on this over craftwebPaul Tarlow wrote:I'm curious if anyone has used a tumbler (rotary or vibratory) to cold work small pieces of glass?
Paul
Very recently
Also I put one up there myself using a rociprolap as a vibro tumbler
Post is
http://talk.craftweb.com/showthread.php ... eadid=1253
Update a week or so later
Have a look if U got any Qs ask here
The set up works very well
Carole
When using the vibro method what stops the glass sticking 2 the bottom of the container ??
![Image](http://www.warmglass.com/SpabSkip.gif)
Paul,
One of the studios I recently worked in uses a hobby type lapidary tumbler to remove the sharp edges from their scrap glass. They teach a lot of children's classes and find that it reduces the number of boo-boos when the kids are handling the glass. I'm not sure what abrasive they are using, but I'm sure they are only using a single, coarse abrasive to remove the sharps.
Re: TUMBLING GLASS
Thanks Carole.Carole Burton wrote:PAUL ARE YOU TRYING TO GET A HIGH POLISH OR ARE YOU TRYING FOR THE FROSTED BEACH GLASS LOOK ?
I'm actually interested in both the frosted ("beach glass") look as well as achieving a high polish.
I've heard that the rotary does a better job of reshaping corners into curves - has that been your experience?
- Paul
Re: TUMBLING GLASS
Hi Paul,
I would like to see what you find out about what you can do with a tumbler. My husband has a vibrating tumbler and if I can use it to achieve an effect that's another tool I don't have to buy.
I'll go over to craftweb and see what they say about what medium to use for possible finishes.
Thanks for bringing this up!
Heidi
Heidi
Re: Tumbling Glass
Another thing these equip is good 4 is as a ball mill 4 grinding stuffPaul Tarlow wrote:I'm curious if anyone has used a tumbler (rotary or vibratory) to cold work small pieces of glass?
Paul
Like frit n colours
Bat wash etc
U just need 2 add round stuff glass / pebbles etc
But not something that will contaminate
Tumbling glass
Paul to get the frosted look I used silicon carbide but can't read the size on the container probably 200 or 300 and used the vib. I was just trying to get a heavy frosted look was not seeking perfection. It takes several weeks but you need to BURB container every few days (tumblers everyday) . Take a piece and wash it off and dry a piece to check progress. Never wash the S>C> in sink or you will be on first name basis with the plumber very shortly. Remember the glass will reduce in size by about 1/4. Use enough water to NOT cover the glass about 4 or 5 tablespoons of S>C> after a day or so liquid should be thick like heavy cream. You may need to add a little water as time goes by. Some people add a little cut up newspaper or dried corn cobs (got it at rock shop) to form a cushion to keep it glass from hitting against each other. Think glass is about 5 on the mohs hardness scale so it would be like polishing agate. Local rockhound shop would be a world of information and supplies, in you part of the country it should be easy to find a lapidary shop. Hope this helps it has been a while since I did glass polishing. Please let me know if I forgot something, will be glad to help.
Carole......S> C.
Carole......S> C.
Tumbling glass
Brian and Jenny, When I was in college some students made ceramic glazes in the ball mill.
They used balls of porcelain. Probably could get them at the ceramic supply. Using them there would be no contamination.
You came up with a good idea about making frit had never thought of that.
Will have to try that. If I could ever get all the grit out of the tumblers.
Thanks for sharing.
Carole.....S.C..
Thanks for sharing.
Carole.....S.C..
Tumbling glass
Brian. Sorry I didn't answer your question. Guess Old-Timers is slipping in. I don't know what a rociprolap looks like. Need to see a picture to give you an good answer. Maybe I know it by a different name.
Carole....S.C.
Carole....S.C.
Re: Tumbling glass
There is a pic over in the link I mentioned aboveCarole Burton wrote:Brian. Sorry I didn't answer your question. Guess Old-Timers is slipping in. I don't know what a rociprolap looks like. Need to see a picture to give you an good answer. Maybe I know it by a different name.
Carole....S.C.
Its a kinda horisontal ossilating action
I guess a tumbler is better 4 rounding the glass we R using it 2 smooth the glass rather than shape it
2 clean the tumbler run it without the grit + poss news paper or something
Tumbling Glass
Brian, Sorry I missed the website you referred me to. Had alway heard it called a lap. Have never used a lap but seen them work but guess the glass settles because the shape of your flat bottom container. By the motion, it tends to go to the bottom and it packs down. One shape tumbler is round and rolls. The vib. is a four sided cut off cone shaped thing without much of a flat bottom.
A friend made me a tumbler years ago, using a thick plastic or acrylic bowl (no lid) (brand Texas Ware) like the size of a large mixing bowl used in the kitchen . You might can find thick left over containers that usually come in a set of three that have lids. Even a SS wok probably would work. You are so good at inventing things you could figure out how to make a top. Heavy
duty Almunin foil might work. Just think it has to have a deep rounded bottom to work and do what you want it to do.
Please let me know how it works and post a pic.
Good luck
Carole......S.C.
Good luck
Carole......S.C.
I use a tumbler all the time with my scrap glass. I use a Lortone rotary tumbler (4 pound size). I use different grades of silicone grit to achieve different finishes on the glass. I have used the tumbled pieces for many different things not related to glass. I put the tumbled pieces in my planter boxes, the glass gives off a nice mix of colors in the sun. I have used the pieces for my aquarium and a media to grow bamboo. It takes from 2-4 weeks depending upon what finish you are going for.
Re: Tumbling Glass
Thanks the rounded bottom sounds a good ideaCarole Burton wrote:Brian, Sorry I missed the website you referred me to. Had alway heard it called a lap. Have never used a lap but seen them work but guess the glass settles because the shape of your flat bottom container. By the motion, it tends to go to the bottom and it packs down. One shape tumbler is round and rolls. The vib. is a four sided cut off cone shaped thing without much of a flat bottom.
Good luck
Carole......S.C.
Re: Tumbling Glass
I have been thinking some more of this vibro thingyCarole Burton wrote:Brian, Sorry I missed the website you referred me to. Had alway heard it called a lap. Have never used a lap but seen them work but guess the glass settles because the shape of your flat bottom container. By the motion, it tends to go to the bottom and it packs down. One shape tumbler is round and rolls. The vib. is a four sided cut off cone shaped thing without much of a flat bottom.
Good luck
Carole......S.C.
The shape of your container
"is a four sided cut off cone shaped thing without much of a flat bottom".
Whats the bottom shape like " V " or " U " or " W " ????
Considering its my first attempt with this rociprolap the finish is very good
I am shure a different shaped bace would sort out the standing still problem
