Menorah sharing time
Happy Holiday to All!!!!!!!!
Very nice. After looking though I think I may have an idea as to why you are having a problem with your bond. I could be wrong, but I'll guess that your piece that stands upright is two layers thick, is that right? Mine are thicker and that little extra surface for gluing may help. Also, is the edge where you are attaching the piece to the base coldworked to a nice flat surface? If not, that may help also. And, one more thing - I rough up both surfaces where the bond will be prior to gluing and once placed, I don't even touch them for at least 24 hours. I hope that helps some.
Take care,
Jackie
Take care,
Jackie
candle cups
a friend who lives in Israel got them for me and I am still working on trying to buy quanities but still searching this out. Will inform any interested when finalized....with pleasure
try this reference
itty bitty candle cup holders
Robin Z <zeeski@worldnet.att.net> -- Monday, 18 February 2002 at 16:46
Licha & Jackie I found the Phone # 1-800-645-7260 & the Idem # 2815 Brass candle socket. Hope its what you want.
Robin Z
NEW: Re: itty bitty candle cup holders
Jackie Beckman <jbeckman29@home.com> -- Monday, 18 February 2002 at 02:00
Me too, please. Have been looking for these forever. Best if they fit a standard size menora candle, but short of running around with one testing it, you'll never be sure they won't wobble around. When I do find the right thing, I'm buying a ton of them. Jackie
Robin Z
huh?
i must've missed chunks of the discussion, so a couple of qns:
...1, was curious about the glueing; what product are you using?
....2, are y'all saying that you did get the candle cups at this number? & is the kind w/ the flat bases (so you'd have to sit them on a flat surface)? only one's i've found on the net have a cup on a flat round circle, w/ a screw in the bottom....
thanks, & happy hanukah....marla
