First Kiln purchase recomendations
Hi,
I'm new to fusing and have been researching kilns. I plan to put it in my basement and have a door opening restriction at 26" - I had hoped to get a Paragon GL24ADTSD but it won't fit.. Does anyone have recomendations on brands and models for a first kiln that can support larger size pieces? thanks-
Lauralei
Re: First Kiln purchase recomendations
Shop at Center DeVerre online (one of the sponsors here) and check out the outside dimensions of all of his medium sized kilns. You can get a Jen-Ken 24 or 28" that if put on its side would go through your narrow door. I say that because I have a Jen-Ken 24" kiln and I just measured it... Maybe the Paragon lid or door can come off and it will be small enough to fit through...Marty at Center DeVerre can answer these kinds of questions and he is more than happy to help you sort through your options and restrictions. I think you can probably get the kiln you want, you'll just have to get creative with either the kiln, the door opening or both.Lauralei wrote:Hi,
thanks!
I'm going to look into these suggestions! I know I can't open the doorway as removing the frame still wouldn't give me enough clearance and Paragon's specs say that you need 33" clear... but I didn't ask if the door could come off - I;ll try that and look into the jen. I don't know anybody that could build one around here to order - but thanks for the thought. But if anyone know of a company that does custom kilns - that might be a good option..
thanks L
thanks L
Lauralei
first, check that the wall isn't load bearing. if not, take the sawsall out for a drive and just cut a bigger door. get a carpenter to come back and frame it out for a 36" door, or 2 30" side by side, which is what i did.Lauralei wrote:Hi,
if it is load bearing, have the carpenter put in a header before removing the doorframe.
Actually it won't Clifford. My basement door opening is 29", and the 24LGAD just barely fit through, on it's side and with the door handle removed. Unless she can remove the door frame, Lauralei's out of luck.Clifford Ross wrote:Lorelei--- I think that if you turn that kiln sideways it will fit through the doorway.
Paul
Paul Bush
Flying Fish Studio
Portland, Oregon
Flying Fish Studio
Portland, Oregon
Thank you for your interest in our GL24 kiln. It will not fit through a 26" door even if the door is removed. However, if you remain interested in a square front loading glass kiln, we have the smaller GL18 kiln. It is 18" x18" x 13" high and it will fit through the 26" door. Please call us if you have any questions.
Also, I do not believe you will be disappointed with a Jen-Ken kiln. They make a quality product. I hope you are very successful in working with warm glass.
John S. Hohenshelt
Paragon Industries
John S. Hohenshelt
Paragon Industries
John S. Hohenshelt
