float/slump/devit?
float/slump/devit?
I am still working on my design for a foundation's yearly award. I have my design and am going to present it in two formats. One clear bullseye with opaque design elements and the other on clear float with the design blasted. I have accomplished the bullseye and I ordered a 3/8" circle of float to slump into a plate mould that will get the blast design. My question, since I am not familiar with float, is will I risk getting devit on my blank during the slump phase if I slump at 1300-1350 degrees. I have read about borax and Spray A but the temps are too low for it to cure. I guess I could use one of the low temp/leaded spray but i really don't want to take a chance on ruining this blank. The fellow that cut the glass at our plate glass outlett also does custom bevels and he outdid himself on polishing the border of this simple blank. It is really beautiful. Thank you. Hopefully I will have a web site after the holidays and will be able to share some of my creations with you all. Ann
Licking the glass will not tell you which side of the glass is the tin side. There is only ONE way to determine the tin side, a UV light. If you fire that glass with the tin side up you WILL get tin bloom at 1100 - 1150. (a scummy surface). First determine the tin side with a UV light, then fire tin side DOWN. If you are dropping 3/8" float glass through a drop ring your diameter will determine how hot to fire it. For a 15" - 20" diameter 1230F works great. But it also depends on how deep you are slumping.
