Recently I purchased a dozen of Jim Berry's sterling silver rings onto which you can attach a cab.
Question: Those of you who are also making these rings, what type of epoxy are you using?
I've made up about 6 just to see how the two-part epoxy I'm using is going to hold up. I'd hate to take them to a show and have the cab fall off while someone is trying it on.
I also made up two with the BondWell ($$$$$) I purchased recently at a trade show.
Judy
Sterling Silver Rings
I have used E-6000 - scuff the glass and finding, clean with rubbing alcohol, let dry, apply good amount of E-6000 to each and let sit for a couple minutes then attach, and don't touch for at least 24 hours. Other people don't like E-6000 and use epoxy but I'm not sure which type. There's some good threads if you search for adhesive or epoxy in the archives.
My rings have hardly any overhang of glass over the ring finding and I can't get them to come off by prying with my fingers.
Susan
Susan
Re: Sterling Silver Rings
i'm using the same thing from burgard studios and i use dymax when i absolutely feel the need to glue....Judy Schnabel wrote:Recently I purchased a dozen of Jim Berry's sterling silver rings onto which you can attach a cab.
Judy
D
Jim is the owner of Blue Moon Glassworks - http://www.austinbluemoon.com - and he sells the ring findings.
You can also get the ring findings at http://burgardstudio.com
Susan
Susan
