Tiny holes after sandblasting
Cristina C.
Post by Cristina C. »
Hello Everyone,
I have recently fully fused white and grey powder onto a layer of clear glass and ended up with a smooth, nice surface. After sandblasting the piece I noticed two small holes (a little over 1 mm in diameter). The holes do not go all the way through, only through the powder part. The layer of glass behind the powder is intact. I was wondering if there is anything I could use (silicon?) to fill the holes without refiring. They really bother me… Your input is much appreciated.
Cristina
bob proulx
Re: Tiny holes after sandblasting
Post by bob proulx »
You probably trapped air and got bubbles that you blasted through. I think you should add powder and refire. If the piece is not that important break it apart and use the pieces to create another piece.
Stephen Richard
Post by Stephen Richard »
And you could consider a long bubble squeeze in the 650C - 677C range to assist the powder to settle.
