dichroic COE82
Beau Lyons
dichroic COE82
Post by Beau Lyons »
Is there such a product as float glass dichroic, and where can i purchase it
Babette (Shawn)
Re: dichroic COE82
Post by Babette (Shawn) »
― Pablo Picasso
Re: dichroic COE82
I believe C&R Loo also sells it.
Re: dichroic COE82
Post by rosanna gusler »
cbs dichroic rosanna
Re: dichroic COE82
Remember that float glass is a commodity whose manufacturers care nothing about fusing compatibility. Even published COE numbers are an average. If you want truly compatible float dichroic, have it coated with your own base glass.
Here is a link for Schott in the USA. I imagine they have an Aussie site as well. This glass is inexpensive enough that it is used for large expanses of building facades.
http://www.us.schott.com/architecture/e ... arima.html
Also remember that dichro pops best when backed with black. You can supply the black with vitreous onglaze colors.
Judd
Re: dichroic COE82
Post by Judd »
You could try using dichro slide papers. They work, but I've found the dichroic coating can look washed out on some floats.
http://www.fusionheadquarters.com/Searc ... rch=dichro
Babette (Shawn)
Re: dichroic COE82
You can send your own float glass to CBS and they will coat it for you. This way you can make sure the glass is from the same source and it will be compatable. *Not so easy or economical from Australia.
― Pablo Picasso
Re: dichroic COE82
Try casting broken tempered low E glass. You have to use plenty of heat to get it to stick to itself.
