kiln adhesive paper - WarmGlass.com
kiln adhesive paper
guaranteed
kiln adhesive paper
Postby guaranteed » Sat Jan 19, 2013 6:43 pm
I seem to have a lot of problems getting my designs to hold together while getting them in Kiln. I have used two different kinds of fusing glue but neither seem to hold even after some time to set. I had seen somewhere a paper that had adhesive that was usable in the kiln. Once the base design is done I think the glue will work for the decoration placement. Any help appreciated.
bob proulx
Re: kiln adhesive paper
Postby bob proulx » Sat Jan 19, 2013 7:31 pm
Hair spray works well, in some cases I use a hot glue gun.
Jeanne
Postby Jeanne » Sat Jan 19, 2013 9:36 pm
Aleene's Clear Gel Tacky Glue works for me. Exposed residue on opals might leave a haze so use sparingly. I use a fine paintbrush to brush on for small pieces. I have had problems lately with hairspray showing up on fused opals, so I stopped using it.
Yardic Glassworks
Postby Yardic Glassworks » Sat Jan 19, 2013 10:33 pm
You are probably thinging of No Days fusing adhesive squares. I don't know anyone who has used them. I find that Elmer's Blue Gel works well and burns off cleanly. It shoild be used very sparingly and not in the center of pieces or it will never set.
Tim Yardic
Yardic Glassworks
Postby Barry Kaiser » Sun Jan 20, 2013 10:19 am
Doing my Glass cloisonne, I use 3M Spray adhesive on thinfire to keep the wire from moving around when laying it up. Worked fine. Easy to apply.
Barry
Lauri Levanto
Postby Lauri Levanto » Wed Jan 23, 2013 3:35 pm
Barry Kaiser wrote:Doing my Glass cloisonne, I use 3M Spray adhesive on thinfire to keep the wire from moving around when laying it up. Worked fine. Easy to apply.
Barry
I have also used 3M contact glue spray. It is easy to lay patterns on when it is sticky. Burns beautifully off.
Stephen Richard
Postby Stephen Richard » Wed Jan 23, 2013 5:49 pm
I hate to rain on anyone's parade, but if there is consistent difficulty in getting the layup into the kiln with out disturbance, maybe the kind of layup needs to be reconsidered. If the pieces are shifting around even with some tackiness, they probably will shift within the kiln too. The glues all burn off before the glass becomes sticky, so if the glass is moving about before adding glue, it will probably move about during the firing too.
From a non-fan of glues to keep glass together before firing unless absolutely necessary, e.g., classes.
theanimallover
Postby theanimallover » Fri Jan 25, 2013 7:20 pm
Glue works well for me. It just stops it shifting on being transported to kiln. After it's in the kiln it doesn't matter. Doesn't need to be set as the tackiness just stops a landslide :)
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 35 guests
