Kiln cement for chipped brick - WarmGlass.com
Jeanne
Postby Jeanne » Fri Mar 07, 2014 5:27 pm
I bought a used kiln and it had a fair amount of chips along the edge of the lid and the body from the previous owner propping it open. I decided to skim a thin layer of furnace cement over the bricks to keep them from flaking. The layer started lifting and peeling as it dried, taking brick chunks with it. I peeled it off and used Paragon cement. Same thing happened. Any thoughts on why this is happening? I had done this once on another kiln without any problems.
charlie
Re: Kiln cement for chipped brick
Postby charlie » Fri Mar 07, 2014 9:55 pm
what harm does leaving the chips do?
Arnold Howard
Postby Arnold Howard » Mon Mar 10, 2014 5:45 pm
Jeanne wrote:I bought a used kiln and it had a fair amount of chips along the edge of the lid and the body from the previous owner propping it open. I decided to skim a thin layer of furnace cement over the bricks to keep them from flaking. The layer started lifting and peeling as it dried, taking brick chunks with it. I peeled it off and used Paragon cement. Same thing happened. Any thoughts on why this is happening? I had done this once on another kiln without any problems.
The coating must be very thin, or it will form a network of small cracks that flake off. You can apply the coating with a rag or sponge.
Sincerely,
Arnold Howard
Users browsing this forum: No registered users and 36 guests
