Still another Float Glass Question
Valerie
Post by Valerie »
I did not do anything wrong...as such.
I dumpster dove a nice piece of 1/4" float.
Cut out 1/8" fiber paper pine trees ect.
spritzed on some borax and slumped.
500 dph to 1200 hold 20min
afap to 1450 hold 20 min then annealed
when I opened the kiln it was perfect..sorta :shock:
It was crystal clear!!! where is the beautiful pale green
I associate with fused float?? now I guess I will sandbalst
the front and slump for the matte finish Drat!
I want that pretty pale green color ](*,)
charlie
Post by charlie »
it may not be standard float, but something else, like starfire.
Ron Coleman
Post by Ron Coleman »
The green color depends on the glass and mostly on the thickness. Most of the pieces I've done from 1/4 inch float only show color on the edges.
Thicker sections and edges will give you more color and another trick is to give the back a texture to help scatter light.
I recently fused some 1 inch square bars of float and they have a kilnwash finish on 3 sides. They glow GREEN in the right light. If sun shines on an end they really glow, about 10 inches ling.
Ron
Re: Still another Float Glass Question
Valerie wrote:I did not do anything wrong...as such.
Valerie
Taking the glass out of flat usually accentuates the "greenness" It sounds like you got a colorless float like Starfire or Optiwhite...
Valerie
just knew you would know
Post by Valerie »
I guess when you dive for stuff
you get what you get
1 more question...it is a rectagular shape
that I want to slump in a circular mold
less than 1/4" hangs over the edge on all 4 corners
if I ramp up then slump below 1200, will
the center drop enough so that the corners
don't grab over the edge?? gonna sandblast
and want the tm matte finish
charlie
Re: just knew you would know
Post by charlie »
Valerie wrote:I guess when you dive for stuff
it will almost probably be ok, but no guarantees. btw: failure could crush your mold if it's not steel. damhikt
