What I'm wanting to do is make simple cut out type moulds of fiber bd thats been preped so I can melt together scraps in to shapes. Should I
drill little vent holes in the bottoms of my excavated fiber board shapes
or is that needless because these are small jewel size shapes.
What type of hardeners are you using and where can I purchase it?? I bought something called "water glass". It was a very thick liquid that I used on fiber blanket. But because of it being such a thick consistency, it didn't soak through. Any suggestions???? Thanks Gail
I don't have the name with me now I'm at work. I work at Swest we
are a supply for jewelrs but not glass stuff. I just paint the hardner on
two or three coats. I let them dry between coats. After a day er two they
are bone dry. then you can sand to smooth.
I don't think you need vent holes. The reason is some people get huge bubbles from wet mulite shelves and when the shelves aren't perfectly flat. On my FB shelves I fire with wet kiln wash all the time and they are definately not flat. The FB allows air to flow even after being ridgidized.
thanks Amy
This week end I'm looking forward to doing some hi heat
experiments for the first time. Mostly I'm working in the 1400 range
so a trip up to 1700 will be a new thing.
