I'm about to fuse a blank that will include clear irid as one layer for the first time. I know the iridized side won't fuse. Frankly, I'm having difficulty discerning which side of this sheet is coated (it's Uro 65-00-96IR). Is there a sure way to figure this out? I've held it up to various light sources and examined the texture, etc. Mystery to me..
Thanks for any suggestions.
Cliff
Clear irid: Which side is coated?
Re: Clear irid: Which side is coated?
Actually Cliff, the iridized layer will fuse. This is a common misconception. The iridized coating will fuse to glass quite well, it will not fuse to another layer of iridizing though unless some of the coating is removed to expose bare glass.Cliff Swanson wrote:I'm about to fuse a blank that will include clear irid as one layer for the first time. I know the iridized side won't fuse. Frankly, I'm having difficulty discerning which side of this sheet is coated (it's Uro 65-00-96IR). Is there a sure way to figure this out? I've held it up to various light sources and examined the texture, etc. Mystery to me..
Cliff
Thanks... I've messed around with this and made a decision about which side is which. It's a bit tricky with this piece because neither side of the sheet are flat...it's quite unevenly textured.
Tony...Thanks for clearing up the issue of whether or not the irid surface will fuse. Come to think of it, I quite possibly extrapolated the idea of it not fusing from the previous threads related to the double irid design technique.
Cliff
Cliff
It WILL, however, often leave a needled or puckered edge. For best results fusing dichro or irid to other glass, it is still best to sandblast
a thin perimeter off the metallic coating. Brock
